FixYa.com
Tags:
RCA DISH Network 311 Satellite System
Dish Network DVR
posted by Mer1972 on May 09, 2007
I have a receiver in my room. It does not have its own box. I works off the reciever from the front room. I recently unpluged the receiver in the front room. Now my tv in my room is snowy. I have checked the assigned channels but still have not been able to fix it.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 14, 2007
Not Rated (0)
satscoop
Rank:Wiz Wiz
Rating: 83%, 78 votes
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
Comment by satscoop, posted on Nov 14, 2007
OOOPPs,I do aplogize I gave you incorrect information!!!the in and out of the diplexer should be aiming toward the wall which should be plugged into the cable coming from the wall which comes directly from the satellite dish outside and The UHF/VHF should be connected to the receiver where it says TV 2 output and the satellite output should plug into the satellite output on the back of the receiver.ALSO if you do not have a diplexer then you will have 2 cables coming from the wall that were installed.One cable goes to the satellite dish and the other goes to the 2nd tv.the cable coming from the wall that powers the second tv should be plugged into TV2 OUTPUT on the back of the receiver.If you do not have a diplxer then the chances are that you plugged the cable going to the 2nd room into the wrong output on the back of the receiver.SORRY about the confusion!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these TV Receivers and DVRs problems?
RCA DISH Network(r) 311 Satellite System
viewsat vs2000
when program is down loaded to... Answer This...
Dish Network 311...
I have a Dish Networ 311... Answer This...
Don't Know how to program
Don't Know how to program Dish... Answer This...
Master reset RCA 311
Hello, i have a RCA 311 decoder... Answer This...
RCA DRD303RA satellite receiver...
I have a RCA DRD303RA satellite... Answer This...
Repair Service
Find TV Receiver and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
