Rca hd52w57 hi! could you tell me where to get schematic for this set?i found a blown resistor on main board,changed it and it blew again r14705.and any web sites to get parts for this set.thank you,phil
I have a RCA HD52W57 tv. The problem is when you plug in to the comp or DVI inputs you have no sound. When you plug in to any other input the sound works just fine. Any suggestions?
Posted on Jul 06, 2010
2 Suggested Answers
  • 1314 Answers
SOURCE: rca hd52w57
i don't repair tvs but ive had two of thees take a dump on me ive got the second one in storage dead lol forget rca they are a french company now and don't want to talk to you now ive been told its just a cheap resister and you can solder a new one in from radio shack to fix it also bigger heat sinks and a faster fan on the bulb side supposed to do the trick you might ask the tv people on this site i do home appliances but this is what i know from my personal experiences
Posted on Sep 10, 2008
Need RCA Sta-3900 schematic diagram
Did you ever find the schematics? I am also troubleshooting my STA 3900.
Apr 05, 2015 | RCA Audio Players & Recorders
Smelled smoke and hot wires, tv went off and never came back on again. opened back and found only one small part looked burned out, ( broken and a little brown on the board.) Part number R14705.
Thats a 27K 1/2 watt Carbon Composition resistor 5% tolerance. You got deflection issues so a replacement resistor will most likely fail unless you discover whaich componenet on the deflection board caused the resistor to burn. The deflection boards have been discontinued for your model which has the ATC321 chassis. But you can get a remanufactured ATC321 deflection board from www.tvrepairworld.com
Jun 12, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA HD56W58
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Nov 09, 2008 | RCA HD56W66 56" HDTV
Rca hd52w57
Sep 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca TV HD52W58
The number you gave for the resistor is incorrect. But I did find a R14705. This resistor is a 1/2W 27K ohm resistor. This part is also in the deflection circuit. This is not a good circuit to play in, and resistor do not burn up by them selfs. There is a problem somewere neir by. The part number for this resistor is 238958.
Jul 31, 2008 | RCA HD52W58 52" TV
Need to identify blown resister r-531 on main amplifier board
How do you know it is specifically that resistor? I suppose you have schematics or something that is telling you R531 may be an issue. If a resistor is blown it will likely be black or discolored somehow.
Jul 11, 2008 | Denon Audio Players & Recorders
Tv problem dead set
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
http://servicemanuals.vstore.ca/
May 20, 2008 | RCA HD52W140 52" Rear Projection...
HD52W140YX!
Check first R14705 to see if burnt! If so then HV Trans is bad. Also if you need schematic try www.servicemanuals.net
Oct 08, 2007 | RCA HD52W140 52" Rear Projection...
RCA projector HD65W140
yea i got my similar tv for 75 bucks blown hv splitter replace with bad resistor blew again 1 day later. i just replaced it tonight along with the flyback hopefully it works
Aug 02, 2007 | RCA HD65W140 65" Rear Projection...
RCA 5-CD Shelf System, RS2654 Fuses
Never ever replace a fuse with a bigger one, you are lucky the unit did not blow up and statrt a fire. When a fuse blows there is usually a reason.There is a short in the main power supply or the output stage. You will need to test for shorts on the main transformer, B+ rectifiers and the main filter capacitors. If that does not show any shorts, you will need to test the audio output circuits for shorts on the audio output IC's. Good Luck
Mar 22, 2007 | RCA RS2652 Shelf System
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
