Question about Candy CPCA240FFK Bottom Freezer Refrigerator
My Candy fridge freezer CPC240FFK seems to turn itself off - light goes out and no sound. If I turn it up to Super it does work, but the fridge is too cold, and when I turn it down it goes off again. Now it is playing up even when on Super, swithching itself on and off. Can you diagnose the problem? SCW
  • suewaller70 Jan 15, 2009
    Thank you dmb23 , for your suggestion. I do believe you are correct about the control board. The first engineer I called told me about this part, but was unable to fix the FF and so put the old one back in. I then called Candy and was told their repair man would come and fix it, his fee was £100 for callout and labour only, so my bill would have been well over the £100mark. So I bought a brand new Beko FF for £200 and am well pleased with it!
    Problem Solver:
  • 5 Answers
I recently found out that there is a component in a fidge called a control board this basically tells the fridge what to do i recently had a variety of problems with my candy F/F starting with the interior light not working it turned out to be the CB had this replaced and now working fine i have been told a CB (control board) can pack up from somethng as simple as a light bub blowing so possibly might be your solution all the best
dmb
Posted on Jan 14, 2009
  • dmb23 Jan 14, 2009
    ok let me know how u get on
Hi ;vejust bought a candy fridge freezer model n0 turned dial to super lights were on constant but now the orange light is flashing what does this mean also some of my meat isnt freezing
What's the model number of your fridge and what type of meats are you putting in and how much at once and what's the temperature of the meat +-, I'll explain everything and give you the best solution.
Regards
Jun 07, 2016 | Candy Refrigerators
My candy fridge freezer stopped working, both parts..... orange light flashing and light inside fridge coming on and off all the time....model number is CPC240FFK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Candy CPCA270FFK Bottom Freezer...
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Apr 07, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
dmb
Jan 25, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy CFC 290 FF
Candy frost free freezers have a 'self defrost' mechanism to remove excess ice build up. What happens is the ice gets packed around the heat exchanger in the back of the freezer and it can't self defrost. This is easy to fix but will require the fridge to be left switched off with the door open for a couple of days so all the ice can melt. Make sure you left the appliance off for as long as you can as if there is any ice left the problem will just come back.
Aug 30, 2008 | Candy CPCA270FFK Bottom Freezer...
Fridge freezer icing up
YOUR DEFROST TIMER COULD BE STUCK,FIND IT ON BACK OR FRONT OR INSIDE TURN SLOW CLOCKWISE TILL CLICK,IF FRIG. IS RUNNING IT SHOULD TURN OFF AND GO TO DEFROST,ALSO THE DEFROST HEATER IN FREEZER COULD BE BAD,OR THE TERMINATOR IN FREEZER COULD BE BAD OR THE FREEZER FAN MIGHT HAVE STOPPED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
May 29, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge Feezes
My Candy fridge freezer done the same. After a bit of investigation, I found that the little plastic shaft from the front temperature dial that connects to the thermostat has snapped. I merely glued it back together and it worked fine.
In essence, the thermostat was turned on to super all the time, and turning the dial anti-clockwise did nothing as it wasn't connected to the thermostat.
Very flimsy I say.
Apr 08, 2008 | Candy CPCA240FFK Bottom Freezer...
CPCA240FFK orange (super) light keeps flashing
If you have the owners manual it should say what that means but I'll see if I can find an operation manual or tech manual online and get back to you.
Dec 27, 2006 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
2,904 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
Shafky Khan
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
