Question about Cosco Alpha Omega Elite 5-Point 22-155
Where in the back seat should it be installed for forward facing
When installed in the middle, with all latches attached, the seat leans quite a bit to the left, no matter what i do to fix it. i want to know if i should install to either side instead to insure maximum safety for my child?
  • a_v_c_s_t_ha Jan 02, 2009
    I have a nissan altima which does have these features and have also employed them, perhaps it's just the shape of the seat and I should move it anyway. Thanks so much for your try on the solution.
    Scholar:
  • 90 Answers
Is there a center strap for the latch system that comes from the top? This is the one that adds a lot of stability. There should be a connection on the back deck or dash of your vehicle. If it's a truck/SUV/Van, sometimes they don't have one. In this case I would use the seatbelt instead and tighten it down as much as possible.
Posted on Jan 02, 2009
Where are the spare wheels kept in a Hyundai terracan looking the bar for releasing spare wheel
The bar to lower the spare wheel is located under the back seat. The back seat is a 60/40 split seat and the bar is under the 60 longer seat. You need to pull the lever at the top of the seat near the head rest and lean it forward as far as it will go and then pull another lever at the base of the seat facing the door, Then lean that part of the seat forward to reveal the spare wheel lowering bar sitting in 2 clips. Take that bar to the back of the car and lift the tailgate. Just to the right of the latch that locks the tailgate in place is a hole to suit the bar. slide the bar all the way home and use the tyre lever to wind (anti clockwise)the spare wheel down. You're welcome.
May 19, 2017 | Hyundai Cars & Trucks
Audi q7 problems
No, it's not a common problem. Slide your seat forward and see if you can clear anything out of the tracks. Slide it back. See if the seat back latch is bent or has a toy, seat belt, or trash under it. Lean the seat forward to get maximum view of the latch mechanism. If it's still broken take it to a body shop because they deal with this stuff all the time after accidents. The body shop is preferable to the dealership unless you have a warranty covering the seat.
Jul 26, 2014 | 2011 Audi Q7 - TDI Premium - Running Board...
Power seat
Most Fordicon1.png products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works besticon1.png to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Oct 21, 2013 | 1998 Ford Expedition
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
Sep 09, 2013 | Computers & Internet
Electric seat won't go forward or back. Sounds like it's trying
Aug 22, 2013 | 2003 Ford Expedition
Bought used Britax Marathon and Roundabout carseats, without the manaul. Need directions on how to install- rear facing for now, but will need directions on forward facing as well.
Go to the Britax website they have a pretty detailed explaination. Basically use the latch clips put your knee in it and pull tight. where you get the real security is though the tether that comes of the back of the headrest, you attach that to the floor clip in your car or under the front seat if you dont have one.
Nov 05, 2009 | Britax Marathon
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
How do you install the car seat for rear facing?
Hey Just posting this for future reference for other people since I see that you posted over a month ago :) ..
To install the car seat in rear facing I used the latch system. (you can use the latch system if your vehicle has latches..they are tiny metal bars in between the seats)
First of all with this dumb car seat I found out that the latch system was not in the proper place so if you find that yours is not where the diagram shows (in the manual) then you'll have to take off the seat cover and manually put them in their place. Then go ahead and clip onto the latches in the rear facing position. If the car seat is too far forward then inline the seat. If the car seat is still not leaning far enough back to be level with the ground (there should be two level marks on the top/side of the car seat) place a rolled towel (or roll a 2x4 in a rolled towel like i did) then clip onto the latches. Hope this helps someone.
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite 5-Point 22-155 Logo
64 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
