Rinnai Integrity 2635 demand hot water unit ignites, runs for a minute or 2, then flame goes out for about 20 secs then reignites and cycle continues. No error is displayed on the remote when this happens but there is a stored error code 12 logged.
    Problem Solver:
  • 16 Answers
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
I have a Maytag Model PGR5710BDW gas range. The bake igniter lights up and the gas ignites after 2 minutes or so. Then the flame goes out after a few seconds and then reignites and this cycle repeats ...
Yes it is the igniter its weak and can not stay within normal range to stay on allowing the flame to stay on.
The part number for that igniter is 74007498 it can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
GENE
Aug 27, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
I have a Bosch Aqua star 240 fx tank less water heater. The unit will ignite and run for 5 sec (Flame visible through window) the flame goes out and it reignites and runs for 5 more seconds and again goes...
It sounds to me like you tried about everything I would. So I think you're already thinking about what I would do next. Try the flame sensor,and as last resort check all connection . Remove wires one by one clean and reattach. If all else fails change cotrol board. It's very hard to fix when it's not consistent. Good luck. Thanks
Nov 15, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Boiler cuts off after abt 20 secs of igniting,hot water goes cold then reignites ,hot water for 15-20 secs then repeat goes cold, burner goes off then rignites...ect was told ntc thermister problem but...
Yes usually it is indeed the thermostat, or Thermistor, all part of the control circuit. You did not indicate what type of setup you have. I suggest you Google for a thing called a service manual. This will aid in diagnosis, and repair of your system.
Mar 29, 2010 | Heating & Cooling
Heat very erratic heat comes and goes hot water last just 30 secs
Sounds like you have a flame rectification fault get your unit serviced
Dec 28, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
My Rinnai R94 LSi stops sending hot water intermittently, resumes after a few minutes, no error message. Could it be water savers are reducing flow below the minimum necessary for the demand sensor? If so,...
II would think that the unit is going out on hil imit because there is not enough psi on the water coming in.Is this unit on well water or city?If it on well water you have run some cleaner in it every six months.L on the side of the heat or inside and there a toll free number to call talk to a tech.
Mar 07, 2009 | Water Heaters
My bosch 21E (infinity style) hot water system has an intermittant fault where the flame does not appear to be able to stay on (or properly light). Once water is started to the unit I can hear the ignitor...
moisture is getting into circuit board, usaully this sealed in a jell which keeps the board protected from any kind off dust,moisture etc which would comprimise the thinking side off the unit. a bosch engineer should be able to do a diagnostics on site.
Aug 08, 2008 | Heating & Cooling
Rinnai Propane tankless Water Heaters R85e-1
Piping of these heaters in tandem is critical. Specified by Rinnai in their design manual, the cold water should be piped to both water heaters with a back-flow presenter installed before the first heater. The hot out piping should be "Tee-d" together and going to your hot water needs.
If piped as per the manual, try turning the water off to only one of the units. Turn on a hot water tap and see if the unit stays on without interruption. Then try the same on the second unit. You may find that one unit has a bad flow control, which is shutting off the flow of water.
You can get more technical help y contacting Rinnai direct at 1-800-621-9419 ext. 207.
Feb 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
