Question about Refrigerators
Thermostat won't move
I have a hotpoint refrigerator side by side and the freezer thermostat won't move
  • 76 Answers
Replace it
Posted on Jan 02, 2009
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Neither refrigerator or freeer is very cold despite moving controls to coldest setting. Notice some frosting on inside of freeer on back part way down.
The defrost system has failed. Most likely a bad heater and thermostat behind the freezer wall panel.
Both controls should be set to the mid-range.
If the heater and thermostat are good then the main control board is bad.
Jul 25, 2011 | Hotpoint HSS25GFP Side by Side...
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My Hotpoint fridge side by side freezer keeps defrosting too much. Mean it melts the ice and some of the food then it freezes again. I check the computer board in the back but didn't see anything wrong. I...
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Oct 12, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator Not Getting Cold--HotPoint HSS22IFMD WW
Take a look to the thermostat first!
Jun 24, 2009 | Refrigerators
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
I have a Hotpoint model HSS221FMD & works when I unplug, & thaw freezer. Then after a while running, the cooling stops on the fridge side & the freezer cools a little & frosts up
This sounds like a bad thermostat. not a very expensive fix but i would call in the pro's mainly due to its location and frail parts. This should be around $100. Give or take a little. Good luck.
Jun 05, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator is not cold
Is there frost in the back panel of the freezer section? Is there air being blown from the freezer side to the refrigerator side? Do you hear the freezer fan running? I have some tips you can check out first then you may need a tech out if they don't help. There could be a problem in the defrost system restricting air flow, a problem with the damper door stuck closed not allowing air to move to the refrigerator side or a problem with the compressor. Best of luck!
http://tclaundryrepair.com/refrigerator
Feb 26, 2009 | Hotpoint HSH22IFT Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
