Question about Apple iPod classic MP3 Player
Itunes won't recognize my ipod.
I'm trying to reset the passcode because I forgot it and my ipod won't even show up on the source list. Help.
    Problem Solver:
  • 6 Answers
Trying restarting your iPod (by holding down the menu and center button at the same time until you get the Apple logo), then plugging it back into the computer. iTunes should recognize it then. I had the same problem recently and that solved it.
Posted on Jan 31, 2009
Itouch disabled
Unfortunately, the only easy and reliable way to reset the passcode on an iPod touch or other iOS device is to perform a complete restore of the device, which will wipe everything on it. Connecting your iPod touch to your original iTunes library will reset any disabled passcode counter, allowing you to make additional passcode attempts, but it will not bypass the passcode.
The good news, however, is that as long as you have a backup of your iPod touch in iTunes or iCloud, you can restore that backup onto your device after you've erased it, thereby allowing you to basically pick up where you left off. Restoring from backup will recover all of your data and settings except for the device passcode, which you will be prompted to re-enter. You may also need to re-enter some passwords for things like e-mail accounts or Wi-Fi networks as these are secured by the device passcode, and thereby lost if you can't remember your original passcode.
Note that even if you haven't already made a recent backup of your device, you can still make one even with the device locked provided you still have your primary iTunes library available-usually the iTunes library and computer that you originally setup your iPod touch with. To do this, simply plug in your iPod touch, right-click on it in the Devices listing in iTunes, and choose the Back Up option from the context menu that appears.
Dec 06, 2013 | Audio Players & Recorders
My ipod shows a connect to itunes symbol. When i connect it, it says "Itunes could not connect with the ipod 'ipod touch' because it is locked with a passcode. But my ipod wont let me type in the...
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library. 3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question.
Apr 06, 2011 | Apple iTunes
Please help reset passcode - forgot the code iPod touch
You can connect your iPOd on the computer which you primarily use with your iPOD, then open Itunes when you disconnect from it it will be no longer locked.
May 28, 2010 | Apple iPod touch
How can i unlock my ipod touch? i forgot my passcode.
The only thing that could make your iPod touch work again is to put it to DFU mode and restore. I have a full instruction about that to guide you step by step, making sure that you're doing the right thing.
However, that process will wipe out all the data from your iPod, you won't even be able to sync or create a back-up because iTunes does not recognize any iPod that is passcode-locked.
That is also why you need to put your iPod to DFU mode first, so that iTunes can recognize it, to by-pass the fact that it is passcode-locked. And, once its in DFU mode, the only thing that you'll be able to do is to restore, nothing else. And you have no other choice.
Click here for instruction on how to put your iPod touch to DFU mode and restore.
For more iPod touch / iPhone tips, click here.
Feb 11, 2010 | Apple iPod touch
Locked ipod won't connect to itunes
put your iPod to DFU mode, that way, your iTunes will recognize our iPod.
see instructions here: http://www.fixya.com/support/r4083816-put_iphone_dfu_mode_restore_3_1_2
Feb 10, 2010 | Apple iPod touch
My ipod-touch is disabled, please read the details
restore it to factory settings using itunes
Sep 10, 2009 | Apple iPod touch
Ipod touch passcode
Do you see in an icon for your ipod touch on the left hand panel of iTunes? It should be listed under "devices". you need to click that first.
Then go to the Summary tab. There is a "restore" button under the Version section. This will restore your iPod to factory defaults. You will loose all the custom data, and will have to re-sync it.
Jul 22, 2009 | Apple iPod touch
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
Forgot my passcode
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Jun 20, 2009 | Apple iPod touch
My itunes won't recongise my ipod
try a program called sharepod see if that works.
Feb 20, 2008 | Apple iPod nano 3rd Generation
Apple iPod classic MP3 Player Logo
37 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
