Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53udx10b no picture have sound
Took off back panel and if you tap on parts picture comes back stays on till next time you use it sometimes put tv on its ok couple min. goes out till i get back to tapping on back componets or banging on set how much to fix problem is it worth it
    Problem Solver:
  • 14 Answers
Sounds like to be you have a bad solder joints, check solder and make sure the they are still attached.
Posted on Jan 11, 2009
No sign of power any where, 5 amp fuse replaced
Find Circuit Q777 (or equivalent) on the main power board (right hand side if you are looking at it from the back. its a voltage regulator most likely.
Part: Panasonic C5314
Partsstore.com has the part. its like 35 bucks shipped
Feb 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
50inch rear projection tv power will not come on
it was the fuse. I took it out cleaned it put back in and is working. Thanks.
Nov 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53 in
the picture turns blue because the blue crt stop working you 'll need a tech
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53 in.
Good Day, hazzletp;
You may have a bad comb filter or one of the CRT's (picture tubes)(cathod ray tube), are going bad. Call an Authorized Service Center and have them come to your home and give you a written estimate b4 repair. Cost AVG $550.00, if CRT is bad go shopping.
Good Luck, big IRISH.
Jul 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Power shuts off periodically
Symptom: Intermittent shut off
Cause: Turn off program timer and video input sensor. redress cabling from front control panel away from blue crt-yoke-HV lead
May 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Power light doesn't shut off.
You're right. It's not only a led problem. Efective. the tv doesn't shutt off due to defective relay S901 in primary power supply. It's a 5 volts ordinary relay, replace it and it'll be fine.
Oct 19, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
