Question about Tappan TGF657 Gas Kitchen Range
Tappan Model No. TGF657BCW-2 (36 inch wide stove built 1990)
Approximately,few months ago noticed while using oven on the preheat setting was taking a long time to heat up.
Upon further investigation noted that on preheat only the upper broiler was on trying to heat the whole oven and the bottom burner was off. From that point on I started heating oven by putting it on bake setting and appeared to bring up temperature better (using bottom burner). NOW to our current problem; starting oven on bake, would smell gas would ignite loud puff sound heard and would eventually get to temperature but then start losing temp.After removing some internal oven panels observed the following:on bake setting bottom bake igniter glows, burner ignites but never goes to the larger flame. On broil setting broil igniter glows burner comes on appears high and when change to low broil keypad beeped showed low on display-- flame spread remained the same -no change.When start oven on preheat only broiler comes on to heat oven-- bottom burner never comes on. At present panels still off. Any help to direct what problem is would be greatly appreciated-dual combine brake/broil valve?, electronic control board- an actual circuit board? Other?
THANKS FOR ANY HELP/GUIDANCE.
  • Anonymous Feb 06, 2009
    Oven won't come on - displays F1 and F2 flashing alternately.  Several weeks before the oven total refusal to ignite, like leebee22's Tappan (same Model No purchased approx 9 yrs ago) I noticed the oven did not ignite right away when turned on and then a loud swooshing noise when it did ignite.
5 Suggested Answers
  • 108 Answers
SOURCE: Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Posted on Nov 22, 2008
duby1990
  • 367 Answers
SOURCE: Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Posted on Nov 26, 2008
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
  • 57 Answers
SOURCE: oven of gas range will not light
Replace lower burner.
Posted on Sep 22, 2009
  • 43 Answers
SOURCE: Ge Oven will get hot on Broil, but won't preheat
check lower oven element,
Posted on Oct 10, 2009
Kenmore Gas Stove, Model No. 790.72404013, oven signals it has preheated to 350 degrees in 7 minutes but it is nowhere near 350 degrees when it does this. Seems to take approximately 20 minutes to reach...
Sorry to read about your problem, I hope this helps you out.
ok it seems you have a offset issue, you need to purchase a oven temp gauge. See what the unit read's, lets say you set the oven for 350, does it read 320 or 380. 20 min for 350 is little on the long side, you may have a gas pressure issue.
I would get a 2nd opinion on this matter. and no, they are not all like that.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Kenmore Kitchen Ranges
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
The top element of the over was not heating (turning red), the over stayed at preheat. I took the element out and took it to a local repair store. They tested the element and said it was good. They...
you can try to snag the wire using a clothes hanger with a u bent in end . if you can see it with a light you may get it back . other wise pull the oven and remove the back to install wire . . some oven do have lifo off doors but they also may have a screw in the hinge . so ck .. and if element was good then look at function or thermo as having the problem..
Nov 08, 2010 | Tappan Ovens
Tappan Convectionaire stove with built in microwave. Purchased in 1985. This is the 4th time the handle on the microwave door has broken off. We were able to replace it in the past, but I cannot find it...
we have the same tappan oven/microwave combination. We are looking for the knobs for this. Its a great oven, but we need these parts. Our microwave handle broke a long time ago and we had one made from wood. If you are going to ditch the old oven would you be willing to sell the knobs?
Aug 25, 2010 | Tappan TMT104E1 Microwave Oven
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Sep 08, 2009 | Tappan Ovens
Tappan gas range TGF364 not heating properly
try changing oven senso located in the oven cavity (upper right or left). its approximately 4-6" long and has a plug-in on the back of the oven
Mar 11, 2009 | Tappan TGF364AS Gas Kitchen Range
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
249 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
meztang
meztang
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
