Question about Knoll MA250 Amplifier
No picture, have sound
I have a knoll projector, denon receiver, insight cable.
I have the sound from the cable box, which implies cable is fine, and I the projector searches for component, but no picture. I believe it is either something got disconnected from reciever where projector can not get a signal.....ideas?
    Scholar:
  • 99 Answers
Sounds like the video cable from the receiver to the projector is disconnected. Check the video output cable on the receiver and the video input on the projector. If they are connected all the way then unplug them and plug them back in to see if that works. If it does not there is probably a break in the cable somewhere or something not set right on the output or input on the receiver.
Posted on Jan 04, 2009
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
I have denon avr 987 receiver i messed up settings somehow. when i have receiver set to dolby digital tv i get sound, but no picture. if i switch the setting to DBS i get picture buy no sound. what did...
Are your DD TV and DBS referring to the same source device or are they separate, say, cable Box and Sat Box?
Start over with the digital audio assignments for wherever you plugged in the digital audio cable from (guessing) your Cable TV box (recommended as "TV" is not usually a great source for audio).
The manual:
http://www.retrevo.com/support/Denon-AVR-987-Receivers-manual/id/696dj079/t/2/
You might also want to define the specific cabling of things if more is required. Exact point-to-point paths and cable styles for audio and video.
Dec 31, 2010 | Denon AVR-987 Receiver
I have a Denon AVR-589 and connected it to my Mitsubishi HC1600 projector via HDMI cable and also connected the Verion cable box (Motorola HDQP 71001)via HDMI cable.I am not getting any picture from my...
Theres a problem with these models on their HDMI board. Take for warranty repair. I work at Scan Audio (authorized for Denon repairs) and I've seen many of these come in for repair. www.ScanAudioUSA.com for more info shoot us email.
Oct 11, 2009 | Denon AVR588 Receiver
Our receiver is connected to our cable box via an HDMI cable. Picture and audio show up fine, then goes out for a minute and then comes back--this keeps happening. Every time the picture/sound disappear,...
Connect the TV directly to cable box to make sure the TV and cable box are ok. If you have picture then the receiver is no good. Some Denons have problem with HDMI board (digital unit).
Oct 06, 2009 | Denon AVR-2308CI
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
Black & White picture
reset the amp by pulling the plug leave for 1 hour disconect the cable box thats the cause the cable box is putting votage into the amp. if the amp is still the same the cable box has detroyed your amp abit of advice these cable boxes are bad news they destroy lots of peoples gear stear clear . any way you amp probably has burnt components loads to fix sorry i have seen this so many times over the years regards kirk ps it not a setting
Sep 01, 2008 | Denon AVR-3806 Receiver
Knoll MA250 Amplifier Logo
76 people viewed this question
Top Knoll Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Knoll Audio Player and Recorder Expert? Answer questions, earn points and help others
