Question about Olevia LT37HV 37 in. HD-Ready LCD Television
How to change picture quality from 480 to 1080?
I am trying to change the picture quality from 480 to 1080 for use with my x box. Do I need special cables or anything?
    Sergeant:
  • 152 Answers
Needs to be hooked to the tv with either an hdmi cable or componet(blue/green/red.yellow/white/) also check the game on the back of the box. some games are only made for 480 and 720
Posted on Jan 02, 2009
Cannot switch the wii to 480p
Go to the menu setting on the tv and select video , then standard, then select the pixel resolution. 480,1080, etc. Select 480, and hit enter. The tv will adjust the picture quality. Hope this helps.
Jun 01, 2014 | Nintendo Wii Console
Change element tv from 480 to 1080
The TV will play whatever signal (480,1080 etc.) it is being given, that is to say if you have 1080 available that is the resolution it will switch to, so there is not anyway to change this.
Feb 06, 2012 | Element Electronics Televison & Video
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
I have an LG 42lh30 I bought less than a month ago from frys. When I opened the box it did seem slightly used maybe it was returned and refurbished or something. I have an xbox and I use a philips 1080p...
Is it a Duplicate Question....Wonder why?
Same reply :0
This is an internal Fault. Diagnosis is required to make sure whether it is Failed T Con Board or Light Engine. I do not think that it would really help by changing the TV settings. This was a Common Problem with Old LCD's where you got Blurry Spots specially while Playing Real Fast Movies or Games. On Few Occasions, it as Corrupted Firmware.
As i cannot see the Video or Screen from here, more likely what i could guess it is an Internal Fault as you have tried using HDMI, Use different Setting Combination's and you got the same Picture Quality with DVD as well.
So, what i could suggest, get back to the Seller and Lodge an Official Complain and get it Replaced. There is no point in Opening and TV and Inspecting it and Replacing Components when it was less than a month ago.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Televison & Video
How can I connect my notebook to my TV
In order to display PC video on a TV the PC must have a TV-OUT function and interface, or you need a VGA to TV converter box.
If your PC has TV-OUT functionality, your user manual will tell you this. If you have, Google "Display PC on TV" and you should find some good articles on how to connect the PC to the TV, and how to change the settings on the PC. NB. even if your PC supports TV-OUT, you may still need to buy a converter cable (but not a box).
If no TV-OUT functionality, E-Bay lists some converter boxes from about £15. NB. the much cheaper cables only work on PCs with TV-OUT functionality.
Oct 03, 2009 | Advent 4211c Notebook
WHY DOES THE VOLUME GO DOWN WHEN I USE CONVERTER BOX?
You will need to adjust the volume on the tv when using the box. The digital sound is different then the sound coming across on analog signal thus do not expect them to be at the same level. The box is not so dreaded, the picture quality is much better then what you get with analog.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
I have a panasonic DMC-Fz8 12x optical zoom camera. How can I adjust the resolution? When I get my pictures developed they are low resolution; you can see the pixels.
Hi!
You need to change the PRINT SIZE and image QUALITY to have have a better picture. Try these:
Press 3049231.jpg then select aa5a871.jpg(Picture Size) . You will be given an option for the number of
pixels - ranges from 0.3 to 7 Megapixel. For better print quality, select 7M.
Next thing that you need to change is the Quality. You need to go back to Menu then 4e59df3.jpg. These are your options for quality:
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Panasonic Cameras
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Logitech Webcam
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
1,001 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
