Question about Sony KP-61HS10 61" Rear Projection Television
KP-61HS10 Convergence IC Replacement
I would like to replace the STK392-560 convergence IC's on my Sony KP-61HS10 rear projection TV. I have electronic repair experience, but have never worked on TV's. I have identified the components to be replaced. I am aprehensive to start without educating myself about the possibility of electical discharge. I've downloaded the Service Manual and searched the web, but was unable to find the answers to the following questions.
Do projection TV's hold dangerously high charges similar to CRT TV's when they are powered down and unplugged? If so, what is the proper discharge procedure?
  • 5 Answers
Hi JWC1,
Yes, there are dangerous voltages present. However, Sony has designed the product so that these voltage levels discharge quickly after powering down and unplugging. Care must be taken when disassembling the board for removal. Mark connectors when unplugging them. Remove all screws holding board in place. Disconnect thick red wire going from the flyback to the HV block by pushing back the boot and pushing the lead inward and turning simultaneously. This unlatches the connection to the high voltage block. The thin red wire from the flyback to the front loosen from tie downs (not necessary to disconnect/plenty of wire length). Not necessary to unsolder the heat sinks from the ICs. After bad IC removal, line up the leads on the new ICs and use patience to insert into the holes. Once you get an IC leads through, hold IC in place and screw back to the heat sinks before soldering. If convergence does not improve, check for open pico fuses. They look like resistors and have an amperage rating silk screened on the PCB.
DJM
Posted on Jan 02, 2009
  • 185 Answers
Yes they can hold a bit of voltage so a high voltage probe will discharge them nicely, something you might not have but can get from ebay if you are going to do this alot. you don't need to be concerned about this though as you won't be doing anything with them so don't touch..
just be carefull when desoldering these stk's use solder wick and patience even a pro can take an hour to desolder these so be carefull not to lift the trace or the situation will quickly get worse. don't adjust these tubes as they are set to the correct alignment already.
How do i center the colors, red, blue and green?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-61HS10 61" Rear Projection...
My KP-62HS10 sony tv got picture smear and cook on right sight. i think some electronic part burn out ?
Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like?The tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Picture seems 3D an display showng duplicate
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board,must require changing it 2 STK convergence ICS and some or all it resistors too.These parts,must be change to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Sony KP-61HS10 61" Rear Projection...
The colors are out of alignment on my sony kp-61hs10 how do I fix it?
Ur convergence is dead.Must know how to solders?Must replace 2 STK convergence ICS,and some or all it resistors.Tries these websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 18, 2010 | Sony KP-61HS10 61" Rear Projection...
Tv looks like the edegs curve and is blury
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Sony KP-61HS10 61" Rear Projection...
Getting double picture in 1080i. checks okay in 480i
REPLACE THE 2 CONVERGENCE I.C.'S PLEASE LET ME KNOW IF FIXED. THANKS,
Mar 15, 2009 | Sony KP-61HS10 61" Rear Projection...
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
273 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
