Question about Kitchen Ranges
Oven temp 30 degrees low
Don't have the book and wonder how to adjust the oven temp on a whirlpool elect range m#rf386pxgb
    Problem Solver:
  • 4 Answers
Usually you remove the temperature control knob. A screw on the back can be loosened to allow the dial to be moved to correlate the temperature in the oven to the the setting on the knob. Tighten the screw, put the knob back on and you are good to go!
I hope this helps
Posted on Jan 02, 2009
  • mdpresco Jan 02, 2009
    Showing my age, I forgot to ask if the temperature control setting is electronic (digital buttons and display) or the "old" technology where the temperature is set with the turn of a control knob.
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Maytag mgr5765dqd temperature problems
Unfortunately, Maytag is now a division of Whirlpool, just one of many. I don't know your range but if it does not have electronic controls, the adjustment is located within the shaft of the oven temperature setting knob. The slotted screw is fairly deep in the shaft and you will need a small flat-blade screw driver with a slim and long blade. If the oven has control electronics, this adjustment will be located on the main board with the rest of the controls and this is normally located in the upright top section of the range.
May 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
Whirlpool sf368leps
can hold down bake the and adjustment comes up can adjust in 10 degree steps 30 degree up and 30 degree down use the temp up and down to make the adjustments
Dec 22, 2008 | Whirlpool SF368LEPS Stainless Steel Gas...
Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
Jun 26, 2008 | Whirlpool RBD305PD Electric Double Oven
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Oven temperature
Press and hold the bake button for 5 seconds, will go to calibrate mode, press the up or down temp to adjust yiour oven + or - 30'
Mar 07, 2008 | Whirlpool SF378LEPS Stainless Steel Gas...
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
204 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
