Question about HP Photosmart R707 Digital Camera
My camera won't turn on
For the past couple of months, our camera battery has been running out quite often. It recharges, but not for long. We left our camera last night at a friends house with lots of kids and we're not sure if something happened to it or what, but when we picked it up, the video light is on, but other than that, the camera is non-responsive. We plugged it in to charge, but the charge light doesn't even come on.
Any guidance would be greatly appreciated!
    Problem Solver:
  • 18 Answers
If you can test the battery seperately do so. i favor using a voltmeter.
Posted on Jan 02, 2009
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
Oct 24, 2012 | Pentax Optio Cameras
Camera won't turn on
check the age of the batteries bc my rechargeable ones only lasted 4 years and they wouldnt even hold a charge for a couple of pics
Aug 15, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
My camera turns on,beeps 3x and then my camera shuts off.
Get some new rechargeable batteries, charge them over night, then put them in the camera. Take many pictures of family!
Mar 20, 2009 | Polaroid i834 Digital Camera
Sony Cyber Shot, camera wont turn on
Try cleaning the connectors inside the battery compartment, top and bottom and then replace the rechargable batteries with disposable alkaline batteries and try again. If this works then the problem may be the rechargable battery pack.
Nov 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Z710 Camera quit working
Pry the battery contacts " in bottom of camera" up GENTLY" with a small flat head screw driver. They bend easy causing this problem. The force from the battery door can cause this. Always use the "rechargeable" batteries, and make sure it is fully charged. I'll bet anything it will work then. Also. clean the contacts top and bottom with a Q-tip, using a little dab of white vinigar on one side, then dry using other side of Q-tip.Then turn on camera without memory card. Kodak cameras love to eat batteries. The older they get the worse. You might have to repeat this every week or couple of months.
Jul 27, 2008 | Kodak EasyShare Z710 Digital Camera
Using rechargable battery with new camera for the first time
If you are using a rechargeable battery, yes you should fully charge it before you use the camera for the first time. Rechargeable batteries are normally supplied without a charge from the factory, but not always. Fully charged batteries may be in storage for a long time before the camera is purchased and unlike modern dry cells, rechargables will not hold a charge for years.
Fully charge your battery, then run it until it has completely exhausted. If you plan to put the camera in storage at some point in the future, always recharge the battery every couple of months or so, to keep it in good condition.
Of course make sure the supplied battery is in fact rechargeable and not a lithium which should not be recharged.
If you found this info useful, please give me a thumbs up...
Mar 11, 2008 | Kodak Easyshare M753 Digital Camera
My camera won't turn on!
Here in my side...
I do suggest that you have to set the correct battery settings in the camera...
Advised to set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
For other camera you just have to go to setup... and look for battery type...
Jun 18, 2007 | Samsung Digimax D53 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
HP Photosmart R707 Digital Camera Logo
51 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
