Question about Microsoft Controller for XBox
Xbox controller wires are broken
The black casing over the wires leading to the xbox have slipped up about a centimeter away from the controller so the wires are visible and several have split. please help me.
  • Got No Idea Jan 05, 2009
    Too late to stop the kids thanks.
    President:
  • Microsoft Master
  • 2,976 Answers
If the wires themselves are breaking, you will need to replace the cable. You didn't say if it is a plug in wire or wired directly into the controller. If it's plugged in, just replace the cable. otherwise, you'll need to replace the controller. Make sure the kids (?) don't pull on the controller when they are playing. I tend to do this when things get frantic, I went wireless.
Posted on Jan 02, 2009
Tip
Xbox Controller to USB Conversion
Did you know the Xbox controller has a USB interface built-in? How would you feel about playing your favorite PC games, with an Xbox controller?
Here is what you will need to get the job done:
  • Xbox Game Controller
  • Male USB Connector
  • Wire Strippers
  • Electrical Tape
1. Using a Male-Female USB extension cable, cut off the male USB adapter, along with a foot or more of cable.
2. You will need to cut off the connector on the Xbox cable, too.
3. Cut the Xbox connector off right at the base, leaving you some room to splice on the USB Male connector.
4. Now strip off about an inch of casing from the end of each exposed cable that we’ll be connecting. There will be a lot of thin silver wires and foil wrapped around a few smaller, colored wires. The silver casing is the shielding, just trim it back enough to expose the colored wires.
5. Using your wire strippers, pull away the casing on each of the colored wires to expose the bare wire.
6. Splice together each wire of the USB adapter to its matching colored wire on the Xbox controller. The Xbox controller has an additional yellow wire, which you can ignore. Use electrical tape to cover up the bare leads, or heat shrink tubing.
7. You should now be able to set up the device and start using it. The first thing to do is to download the XBCD drivers (download here), and run the installer file.
8. Once the drivers are installed, plug in the controller and it should detect and install the drivers for “XBCD XBox Gamepad”. Now go to Programs -> XBCD -> Setup Utility and set up your new gamepad!
on Jul 12, 2010 | Video Game Consoles & Games
When turned on error E-73 shows up
that's XBOX hardware issues, which means that it should be fixed right away. In our case before in Microsoft, once customer get any error that start in "E" that hardware issues and what usually do is just replace the xbox specially if it is under warranty. If you get you xbox fixed by other technician, the warranty will be broken and in can be easily detected by Microsoft XBOX server, it will be better if you are going to call the xbox hotline now.
Dec 28, 2011 | Microsoft Xbox 360 Console
My xbox is getting power from the power outlet but the second cord that connects the xbox to the ac adapter brings no power over to my xbox
Bad connection or the wire has a short, ask someone who knows like the geek squad at Best Buy, if they can't help they might know who might.
Oct 02, 2011 | Microsoft Xbox 360 Console
I keep getting kicked off of xbox live while playing games..
keep xbox away from any carpet/rugs static electricity place xbox on an anti static mat/bag or a piece of newspaper also make sure there are no electrical wires showing from the leads leads that attach to the xbox
hope this helps
Oct 31, 2010 | ASUS RTG32 Router
Xbox 360 Controller: My xbox 360 controllers wont sync at all no matter...
Try replacing the batteries in your controller. If this does not work then try the controller on another console. Failing this your controller is broken.
Best recommendation is to buy a wire and use it wired.
May 18, 2010 | Microsoft Xbox 360 Controller
How to open tray when it don't want to open
You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Aug 11, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Controller for XBox  Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
