Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My side by side whrilpool refreg
It dose not despen water or ice i already change the filter and i hear clicking noise
  • 1 more comment
  • Anonymous Jan 09, 2009
    Not making ice althoughthe ice water works ?
  • Anonymous Jan 11, 2009
    the water works but the ice maker will not work. the waster is at the top but it will not go into the ice maker
  • Phil Brantley
    Phil Brantley May 11, 2010
    Is It clicking when you press the water switch in the door or when ?
    Problem Solver:
First of all, is there a reset button that needs to be pushed after changing filter? Mine has one. Check around the sides and top inside the fridge for a little button and push it in.
Is the water turned on going to the fridge?
If it was working before you changed filter, maybe the water line got kinked somewhere and no water can come through.
Also, if filter isn't reinstalled correctly, no water can come through it. Make sure the filter is not upside down and that the holder is screwed in all the way.
Posted on Jan 06, 2009
The ice maker dose not fill up with water.
Have you checked/changed your water filter? A bad water filter will stop/slow the flow of the water to your ice maker. Are you still able to get water from the dispenser? If you are, then it could be a bad ice maker, or the fill tube could be frozen, which is the main tube where the water comes in. This could also be a bad water valve inlet.
Mar 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Making very little to no ice water filter has been changed out already
could have a bad water valve,next time send model number.on some of the ice makers you can pop off the white cover and on the right hand side you'll see to holes close together,you can jump out the ice maker to see if the water valve is sending up enough water to fill the ice maker,stick the end of the wire in each hole,you'll see the middle part start turning,when the theeth of the ice maker are at 9 oclock pull the wire out and watch to see the ice maker fill.if it doesn't fill and you hear the water valve turn on the valve is bad and has to be changed out.let me know how you make out
Jun 02, 2010 | Kenmore 53632 / 53634 Side by Side...
Our ice-maker stopped working on the hottest day of the year!
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klhggkllkg
Jun 01, 2010 | Maytag MZD2766GES Side by Side...
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
My Whirlpool side y side refrigerator purchased last year august is not dispensin water but making ice. I have replaced the filter but still not dispensing water.
there iis a switch on the door dispenser that operates when you slip your glas up for cold water and in doing this you should hear a click from the solinoid when this part of operation takes place
if no noise then probable the solinoid is faulty
if there is a noise then disconnect pipe going up inside of door which in toe kick area try pushinhing on switch to operate if no water comes out remove filter and try again, water should come out where the filter is situated
if no go replace water valve
Nov 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Waterline Rattling AND DIRTY ICE CUBES
Sound like a clogged valve or a dirty water filter. Change the filter then try it. Good luck.
Nov 09, 2009 | Refrigerators
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Water despenser in door drips water
Hi!!! you seem to have a problem that everybody in the world has..Its normal at there is nothing you can do about it unless you install an antisyphon in the water line kitchen aid has one.Good luck..
Jan 05, 2009 | Frigidaire FRS23H5AS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
110 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
