Question about Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Machine does not turn on
Left the Saeco Machine on and now it does not turn on at all. I opened up, but there were no buttons for resetting the fuse. Is there a fuse that I should buy or a switch that can make it turn on?
  • espressofixr May 11, 2010
    What is the exact Saeco model you are needing help on?
    Problem Solver:
  • 14 Answers
It is probably a micro switch not getting a contact to complete the circuit. There are several of them on the machine. Take all removable pieces off and put them back on making sure they are all seated properly. ie- there are three micro switches just in the brew group service door on the right side of the machine. There is also one on the dregs box.
Posted on Apr 22, 2009
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
Hello. I have a Saeco Magic Cappuccino Plus machine, which should be similar to the Saeco Magic Cappuccino machine that was occasionally discussed on FixYa. My machine was working OK until yesterday. I hit...
Hi
Yes. The thermal fuse is incased in a browish/red cover and is held on to the boiler by a clamp that holds the thermostats on. Slide the fuse out from the clamp and slide the cover off the thermal fuse. Test with a ohms meter. If its bad you should get no reading. You can get a new 182c thermal fuse from Radio Shack, electronics store, or appliance store. If no luck there online espresso machine retailers like Seattle Coffee Gear, Whole-Latte-Love, 1st-Line should be able to help you. Do not try to solder the new fuse in. It has to be crimpwed on or it will blow again.
May 07, 2011 | Saeco Magic Cappuccino Espresso&Cappuccino...
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
My saeco royal professional has no power, no lights. What's up?
Hi
First I would check the switch on the bottom left side of the machine and make sure that it has not been turned off.
If it is on you may have a fuse out on the board. It is a very special fuse. It is a 35Ma timed lag fuse When we change them we put in a 50Ma Timed lag fuse with no problems, because the 35MaT is hard to find.
May 05, 2010 | Saeco Royal Professional Espresso Machine
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
Saeco Incanto Classic has no sign of life. Has horseshoe type heater, fuse has continuity. Power switch tests ok. May have experienced power outage.
Hi
There are 2 boilers in your machine. There is a main boiler on the left rear of the machine. It should have 2 thermostats that each have a reset button. The buttons are between the 2 wires on each thermostat. They are on the outside of the boiler between the boiler and the outside of the machine. Push the buttons and then try again.
Oct 23, 2009 | Saeco Incanto Classic Espresso Machine
Saeco how to reset
called saeco helpdesk and with their assistance found the reset button inside the machine (open the top with a screwdriver). there are three termostates. on the middle one there is a button. when you push it you hear a metallic sound. then you have to close everything and put it on again.
how to avoid this problem: it is important that there comes no air into the heater. So you have to watch the water supply carefully and leave the air out from time to time.
Sep 16, 2009 | Saeco Aroma Espresso Machine
Can't find circuit breakers on the boiler for Saeco Incanto
Hi
It depends on which boiler you have. If you have the round boiler (looking from the front top down, they will be on your left side). They will be on the bottom left side of the boiler. There are 2 of them on the round boiler and there are 2 wires to each thermostat. The button is between the 2 wires on the thermostat. You need to push both buttons. If you have the square flat boiler there is no reset button but a thermal fuse on the back side of the boiler. You have to remove the steam boiler ( horseshoe) to work on the flat boiler. FUN
Jun 17, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Vienna Digital does not turn on
Hi
There are a couple of things that might be wrong.
There is a reset button on the thermostat on the back side pof the boiler.
There is a fuse on the power board of the Digital its on the left side of the board.
You have to remove the top to do either and that is fun on the Digital.
May 01, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic Comfort Plus Espresso Machine Logo
234 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
