Question about Bosch PowerStar AE3.4 AE3.4 Point-of-Use Electric Tankless Water Heater...
Powerstar bosch tankless water heater ae3.4
When the breaker is turned on the copper gets hot automatically and the water pipe line gets to out and swells up the pipe line.
The water is not even turned on yet.
Can you tell me if the device is faulty.
    Scholar:
  • 68 Answers
Yes the device is faulty. the unit should not heat water unless a tap is turned on. Call in a service rep to assess the problem. Do it quickly your description doesn't sound good.
Please rate this response and Good Luck Phil
Posted on Jan 02, 2009
I have a Bosch Powerstar Ae115 and the left cutout keeps tripping. It has worked great for 5 years. When i reset it, the water gets warm again(never hot as it was before). What could be causing it to trip?
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Jan 12, 2014 | Water Heaters
AE 125 Just Stopped Working Altogether,,,Still Has Power But No Light Or Hot Water?
Turn circuit breakers fully off and then back on.
Use nose to smell for burning inside main panel.
Make sure you are getting 240Volt and not just 120V from one leg of the breaker.
Do stress test on breaker panel.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
Least expensive solution: Replace tankless computer for $285 buying tank-type electric water heater from local box store.
If tankless computer is new, then call installer.
If you installed it yourself, call professional installer.
Gene
h
Sep 24, 2013 | Bosch PowerStar AE125 AE125 Whole House...
There is power to the system but when you turn water on elements do not come one and heat water. all phases have 238 volts to them. why will system not turn on and heat water
Do you have 3-phase water heater? Is this balanced or unbalanced 3-phase unit. Add comment and describe product in detail, including brand since i have some service resources for both types.
Or do you have ordinary residential split-phase 240Volt Bosch tankless computer that heats water, and has 2 or 3 separate elements, and a separate circuit breaker supplying power to each element? And testing across both hot leads coming from each breaker yields 238Volt?
Copy following link for Bosch tankless manuals, with brief troubleshoot section that does not provide detailed service procedures for repairing tankless computer:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
If this is new water heater, then call installer. If you installed yourself, then remove tankless and return to seller for refund.
Tankless computers require certain amount of water flow to activate computer sensors. Turn on Hot tap and listen to pipe to hear if water if flowing through hot pipe. Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter usually located just above where cold water connects to unit.
Delime tankless ... and use water softener. Tankless cannot be exposed to more than 11 grains hardness in water, or parts will fail within 2-3 years. Simply deliming tankless heat exchanger each year will not maintain full efficiency... although for typical family of 4, tankless comper water heater costs $100 more to operate than tank-type heater according to manufacturer's promo literature and independent studies.
Call local technician who specializes in fixing tankless computers. For plumbing problems call local plumber. These are two different things.
If tankless computer is older, then cut losses, and buy tank-type electric water heater at Lowes for $285 and make quick changeover and have hot water same day. Sell old tankless on ebay and cheat next guy, or sell at scrapyard for $3 per 100.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
Aug 03, 2013 | Powerstar Water Heaters
AE-9.5 Bosch Tankless Water heater - no manuel or installation instructions
This is a "point of service" tankless water heater that was manufactured by BOSCH. BOSCH is now Bosch-Climate.us. Technical support is available at 866-330-2729. P.S. check this site: http://tanklesswaterheaterz.com/bosch-ae-9-5-powerstar-1-5-gpm-point-of-use-indoor-tankless-electric-water-heater-reviews/
Feb 02, 2013 | Bosch AE-9.5 Electric PowerStar PowerStar...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
No Hot water...why Bosch tankless water heater, 2 years old
I dunno ... did you turn it on?
What kind of result do you expect from this kind of question???
Oct 09, 2009 | Bosch PowerStar AE115 Tankless Water...
Bosch PowerStar AE3.4 AE3.4 Point-of-Use Electric Tankless Water Heater... Logo
140 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
