Question about Whirlpool Dryers
It will not heat up
It works and runs it will not blow out heat. what could it be
Try your thermostat. Put a meter on both terminals and see if it has continuity. If it doesn't it is open (blown). They are not resettable, replace it.
Posted on Jan 02, 2009
My heat kicks on, I can hear it and feel heat when placing hand on vents. However,Nothing blows out.
Blower is not running ? Or is ?if the blower fans not working check fuses or replace motor , if your heat cycles and your blower blows cool air , its likely a heater core issue
Nov 09, 2015 | 2007 Ford Freestyle Limited
Amana ptac during heat mode will blow hot air , then blow cold , but will cycle back to heat eventually is this Normal?
if the fan switch is in the Run position and not the auto position you are getting cool are when the heat element is not on. this is kind of like a way to circulate the air. look for an auto setting it then should only come on when needed. Keep in mind it is normal for the fan to start blowing before the heating element is warmed up, this prevents it from over heating, or coming on when the fan is not working
Nov 26, 2014 | Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
My down stairs unit is blowing out warm air. the fan outside is blowing cool air....
Your unit is running in heat pump mode...hope you knew that you had a heat pump...
Anyway the problem would either be the thermostat or the reversing valve...
It will take some detective work to figure out exactly which is causing your problems...
heatman101
Aug 16, 2010 | Ruud UBHC Air Conditioner
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Intertherm electric furace
It sounds like the coils are fine if you are getting heat. They are likely shutting down from overheating after being on for awhile. Check your filter and overall air flow to make sure it's adequate.
Mar 03, 2009 | Intertherm P3RA-048K Air Conditioner
2006 Ford explorer/No heat /overheating
Sounds like you are either low on coolant, or a head gasket failure.
Nov 18, 2008 | 2006 Ford Explorer Sport Trac
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
