Question about Belkin Wireless Cable/DSL Gateway Router
Have a belkin wireless gateway router mod # f5d6231-4
I went into setup so that i could secure my wireless picked 128bit and generate code but half way through i lost connection and never got the code but now it shows secure and i have no way to get into it. i have tryed to hardwire login but i cant get in ??
  • Michael Ward May 11, 2010
    Need for info to better assist you?
    Scholar:
  • 108 Answers
With the router powered on, press and hold the reset button for exactly
seven seconds, this will restore the router to factory default.
Note: By default the password on the router is left blank, and the
default IP address is 192.168.2.1
Posted on Jan 17, 2009
We are trying to connect our wireless and are having problems first of all we do not know what wlan security setting to put in and then we have know idea what a wpa key is?
All the settings are in your router configuration. Whens etting up your router it will have a wireless setup section, in this section you set the security type;
WEP - (64bit or 128bit) - Wired Equivelant Privacy
WPA - (64bit or 128bit) - Wi-Fi Protected Access
WEP- 64 bit is 10 character numeric key and 128 bit is 20 digit numeric key (eg, 1234567890) WPA- 64 bit and 128bit are a passphrase comprised of anything numeric, symbols or letters (eg, 8taq*1%9)
You set your own WEP or WPA security keys and the best way to do so is to enter into your routers configuration. To do so do one of the following to find the gateway ip address;
Windows XP:
Click Start
Click Run
Type "cmd" without the qoutations and hit enter
A black screen will appear and in there type in "ipconfig" no quotations and hit enter
it will show up looking something like this:
Gateway IP........................192.168.1.1 (Example)
Write down the Gateway Ip Address
Open a browser from a computer connected hardwire into the router and type in that ip address into the browser bar and it will take you to the router configuration page.
Windows 7:
Click start
in the search field type "command" no quotations and hit enter
Open a browser from a computer connected hardwire into the router and type in that ip address into the browser bar and it will take you to the router configuration page.Without knowing what kind of router you have though I cannot help any further as all router setup pages are different.
If you can give me more information on your router I can guide you to a page that will show you how to setup wireless on your specific router. I hope I have been helpful and feel free to comment for further information.
Jul 20, 2011 | Computers & Internet
Tip
Wireless Part Configuration of Belkin routers without CD
Wireless Part Configuration:
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Step 1: Wi-Fi Protected Setup (WPS)
In the Belkin router Setup page, on your left hand side, you may have Wi-Fi Protected Setup (WPS) below WIRELESS. If you have WPS then click on it. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be Enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
Select Security found on left side of router setup page.Security mode will have the following options,
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Usage of above security modes for various devices:
  • WPA / WPA2 (PSK) ------for vista & windows7 computers
  • 64-bit WEP -------for windows XP, MAC, XBOX, Play Stations, Ipods, Ipads (recommended)
  • 128-bit WEP ------same as 64bitwep, but not recommended
  • Disabled------to disable the wireless security
Disabled: If you think there is no need for security for your Wireless network or if you are willing to make it as a hot-spot then you can select the option as Disabled and Click on Apply Changes.
WPA/WPA2: If you are selecting the Security type as WPA/WPA2 then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
64bitWEP: If you are selecting the Security type as 64bitWEP then you will be able to see the Key 1 with 5 empty boxes. You need to type 2 numbers in each boxes of Key 1. You can also use letters A-F along with numbers 0-9 to make your password more secure. Password is case sensitive. After filling those details click on Apply Changes directly. You must not type anything in Passphrase and click on generate. If you do so, it will generate a password automatically.The 10digit value which you entered in key 1 is the password for your wireless network.You need to enter the same password without any spaces in between in your computer to get connected to your wireless network.
128bitWEP: If you are selecting 128bit WEP, then you need to follow the same instructions as above but you need to enter 26characters in 13 empty boxes.
Step 3: Channel and SSID:
  • Once you are done with that, select Channel and SSID found on the left side of RSP.
  • Change the Wireless Channel to 1 or 6 or 11 (these are the best non- overlapping channels for wireless networks).
  • Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
  • Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
  • Once you are done click on Apply Changes.
Now the Router is configured for wireless devices.
Connecting your wireless computer to the wireless network:Make sure the wireless switch is turn on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected.
on May 05, 2010 | Computers & Internet
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
I need a security key code or a passphase
this is generated when you setup wireless networking and is required when you connect you computer wirelessly. connect you computer with a network cable first. log on to router and set up wireless networking. when you generate the keycodes, make a note of them, then you can enter it when you connect wirelessly.
Feb 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi I cant get my PSP to connect to my Belkin
The WEP CODE Is the Password for your wireless network
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Dont no my belkin security code can u help me plz
You need to access the router's setup page by going to http://192.168.1.1 you can see it under the wireless security tab
Jun 10, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Securing my belkin router with a network key
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.2.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is admin and password is blank (this is generic to all the belkin routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a belkin router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Feb 20, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Cable/DSL Gateway Router Logo
240 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
