Question about Code-Alarm Code Alarm Transponder
Transit not starting
No glow plug light coming on my transit,. now it wont even start,. can u help,. p.s its x,reg.
  • jason skovly May 11, 2010
    what year/make/model and brand of unit that is installed
  • 99 Answers
The engine in this model doesnt need glow plugs, Its direct injection. If the van is not starting then it will be fir another reason. Ok, can you get a 17mm spanner and loosen the pipes onto the fuel injectors. Crank engine and see if there is fuel coming out. If not just crank it for a few minutes and see if some appears. If fuel appears, tighten pipes and crank for little while longer, see if it goes. If this doesnt work, i have a few more things to try.
TL
Posted on Jan 24, 2009
Starting problem on kangoo
Check the big fuses in the power distribution box under the bonnet ,this is a UK reg vehicle kept outside no doubt and these fuse connections under the bonnet do get damp ,if still no joy for whatever reason then but a manual push button starter switch and wire them in direct manual overide ,power to switch then direct to the glow plugs ,so when the light dont come push button in for 10secs and no more and away you go,Clean the big fuses and spray with some 3in1 or a oil can with engine oil not that wd40 and lubricate the connections where the fuses push into.
Jan 19, 2014 | Cars & Trucks
Had 04 transit connect for 6 weeks. always started fine till week ago when turned cold. glow plug light only shows for about 1 second, replaced glow plugs but still the same. can only start every morning...
Sounds like the timer is bad. Since you have power when warm, the power relay must be giving the timer juice. The way it is suppose to work is you wait until the glow plug light goes out and then try to start. In cold weather it should take longer for the glow plug light to go out.
Nov 03, 2013 | Ford Transit Connect Cars & Trucks
Vw sharan w reg turns over and sometimes fires but then dies, now wont start at all.
Just some info could be filter or fuel pump. copy and paste to google search. diesel which is takes some time to crank.
https://www.youtube.com/watch?v=yRMTEAKsScE
Aug 04, 2017 | Volkswagen Sharan Cars & Trucks
Glow plug light wont go out
Your diesel vehicle is equipped with glow plugs, and also with a Glow Plug Light that will either come on and stay on, or flash or blink when a fault is detected by the ECU (engine management unit). When the Glow Plug Light comes on, the ECU stores information about the condition that has caused it to come on.4 Jan 2016
Is It Safe to Drive With the Glow Plug Light On? ' YourMechanic Advice
https://www.yourmechanic.com/article/is-it-safe-to-drive-with-the-glow-plug-light-on Glow plug light wont go out Google Search
Oct 25, 2017 | Ford F-250 Cars & Trucks
I have a Mazda BT50.It just wont start.It needs to be kickstarted all the time.I've changed the glow plugs and even sent it to Fuel Injection but they cant find the fault.What can I do now.Ignition...
had the same problem
found the fuel pressure regulator faulty, sending the wrong info to the computer
replaced fuel reg and rail ( comes as one unit- cheaper to by from ford)
no more problems, starts both hot and cold
May 20, 2011 | 2008 Mazda B Series Pickup
Glow plug light goes out as soon as i turn the ignition on, have new glow plugs but still does the same.. could you help me with this. I have ford transit 2002, 2lt diesel engine
thats how it should work...the glow plugs on those engines dont really help cold starts they are fitted to clean up the emmisons from cold starts as it stops the tree huggers from complaining to much.....
Oct 26, 2010 | Ford Transit Connect Cars & Trucks
Had problems with vw caddy van starting when warm,...
2004 vw 2000sdi caddy van wont start some mornings you need to wind it over before it fires, immediately after it fires you can switch off ignition and it will start first time and continue to start all day. vw dealer says no fault codes present. gloplugs renewed, new battery,fuel problem? Has anyone come accross similar problem I
May 20, 2010 | Cars & Trucks
I have a citroen xantia 2.0 hdi,glow plug light goes out to quickly not on long enough,problem still there even after new glow plugs were fitted, would apreciate help thanks.
have you tried the glow plug relay? or if you have a test light see if theres power to glow plugs when light is on,should only light for 5 or so seconds.some of the newer hdi dont even use the glow plugs till temp is very cold,i have a 2006 2.0 hdi van and glow plug light only stays on for a second or so,and its been like that from new! is the problem just bad starting? and is it only when its cold? if you have a manual priming pump for fuel under bonnet,trying pumping before starting it could be fuel prob?ie air getting into fuel system
Nov 02, 2008 | Peugeot 604 Cars & Trucks
Code-Alarm Code Alarm  Transponder Logo
413 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
