Question about Gateway MT6705 Notebook
Will not power up
Yeasterday it worked fine, got my mailok then came back to it 2hrs later and it was off, and itn will not turn on.
1. no lights
2. no sound from hard drive
3. no souind or air movement from fans
4. power supply measures 19.2 not plug into the computer
5. battery checks 1 yellow 3 green
6 will not power up on ac or battery
  • stanh104 Jan 02, 2009
    I HAVE POWER @ THE COMPUTER JACK
  • hlhusker Jan 26, 2009
    I have the same problem.
    Notebook just shutdown, in use without warning.
    Will not attenpt any real activity with powen on attempts.
    Only a RED led flashes at the front, when the power on button is pressed.
    The red LED only flashes with the battery, and without the battery and AC power cord, there is NO activity. Is it possible that my battery is dead, and the AC connector is not functioning?
The solution is really simple. Just take out the battery, connect the a/c cable and try to turn it on again.Chances are that it will start without problems.
Posted on Aug 11, 2009
Its your dc power jack in the back. these computers are prone to those going out. the peice is only about $25 and shouldnt b much to have some one install
Posted on May 10, 2009
    Novelist:
  • 176 Answers
If the a/c adaptor is plugged into a power strip, reset power strip by turning off and on. If there's no power on strip use another power outlet.
Make sure PC power supply is good and securely connected.
Posted on Jan 02, 2009
My Jazz Ultra Tablet 9.7 won't turn back on. I just used it. I selected "power off" instead of just letting it sleep and 10 mins later it would not turn back on. It's been charging the whole time. HELP
On the backside there should be a reset button. Probably won't be very noticeable but should be there. Just push it in with a pen or something similar, should take care of itn
Jun 14, 2014 | Tablets & eReaders
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
I have a older magnavox model 25ts52 the power in the house went off with the tv on 2hrs later when the power came back on the tv will not turn back on
90% chance if set is opened(follow power cord inside) the line fuse--usually a plug in type around 4 amps (will be marked on fuse and board) is bad.
Nov 05, 2012 | Televison & Video
2003 BMW M3 Convertible - won't start - electrics dead
Main cable from battery has a joint in front footwell check this
Apr 13, 2017 | 2003 BMW M3
My ups cannot able switch on
just off the UPS and turn on the power for 1-2hrs your ups will be work fine
Jul 03, 2009 | Computers & Internet
Bosch hydro sensor All my programs say 2hrs inc quick wash?
Hello!
I hope that the manual will help you.
Seems that there is a trouble with the connection.
http://manualsbrain.com/ru/manuals/803920/?page=1
Jun 19, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
My Magellan Roadmate won't turn on
THere is nothing wrong with it. On the left side of the unit pull up the rubber cover. You will see a very small switch and a button above it or below it.
With a a pen slid the switch, and push the re set button. Then slid the switch back. and turn on the unit the way you normally do. If it doesn't light up
either you did it wrong, the unit is discharged, or there is something wrong with it. If nothing works call Magellan and if it is still under service, they will help you. Good luck to you.
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Craftsman 1/2 HP Garage Door Opener
The tempatures in the morning have been cool, about 40F and an hour later slightly warmer, maybe 45-50F. Thanks for the suggestion and I am going to have the cale checked for shorts or opens. The opener is direct wired to the breaker, so no outlet is involved. The morning have been cooler since my original post and have not seen the problem again. Maybe its Grimlins? I'll update if anything wrong is found. Thanks!
Nov 01, 2008 | Electrical Supplies
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Gateway MT6705 Notebook Logo
334 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
