Question about Dell Inspiron 1300 Notebook
BLUE SCREEN W/ MESSAGE STOP: C000007B BAD IMAGE.
AFTER RUNNING A CHKDSK /F /R I TRIED TO GET BACK INTO MY LAPTOP. THE COMPUTER BOOTS UP & I SEE THE WINDOWS XP SCREEN. THEN I GET A BLUE SCREEN WITH THE MESSAGE: THE APPLICATION OR DLL\??\C:WINDOWS\SYSTEM32
WINSRV.DLL IS NOT A VALID WINDOWS IMAGE. PLEASE CHECK THIS AGAINST YOUR INSTALLATION DISKETTE.
I TRY REBOOTING THROUGH SAFEMODE AND I GET THE SAME MESSAGE.
IS THERE A SOLUTION TO THIS PROBLEM WITHOUT ME LOSING ALL OF MY FILES AND DATA?
    Scholar:
  • 155 Answers
Try to look for your windows xp cd.
Turn the computer off. Restart it and start tapping f12 right after.
Insert the cd. Choose the option that says CD/CDRW/DVDRW from the screen and press enter. Watch out for a prompt that will say 'Press any key to boot from cd'. press any key as soon as you get this. If you miss it, you'll get the error again. You should get the blue windows setup screen if you caught it at the right time.
Wait until you get the 'welcome to setup' screen.
Press R.
Follow any other instructions that you may get until it gives you the C:\> prompt.
Type in bootcfg /rebuild.
Below is a listing of the common steps you are likely going to encounter.
* Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
* Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition". If you have Windowx XP pro edition, enter 'Microsoft Windows XP Professional'
* Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
Then type 'exit'. and let the computer reboot. If you get two options for microsoft windows. Choose the one that says what you entered when you were in the recovery console.
If you are able to boot correctly after those steps, go to start>click run. Then type msconfig. Click ok. Click the boot.ini tab. Click 'check all boot paths'. Click ok or yes. click close and restart if prompted. You shouldn't get the prompt for two microsoft windows anymore.
Posted on Jan 02, 2009
    Novelist:
  • 101 Answers
You can do a repair installation if you have the Dell XP Installation disk for your version of XP (probably Home Edition). Restart the laptop and press F2 when you see the Dell splash screen to get into the BIOS setup. Ensure that the system will boot from the CD/DVD first. Save if necessary and restart with the Dell XP disc in the drive. Press a key to load from the CD/DVD. At the first menu select the first option to install. The installer should check for previous versions of the operating system and find the current installation. Press R to repair and it will go through the installation process while keeping your programs and data intact.
However, I presume you were having disk problems before you ran the chkdsk routine. You may have a failing hard drive, which could be why some files appear corrupted. If you do not see the previous installation but rather just the partitions with the volume names, do NOT install onto those partitions as this will erase your old data. Seek professional assistance ASAP to retrieve your data by placing the hard drive in another machine as a secondary drive.
I encountered this same error while doing a ground-up reinstall from the XP Pro CD, after several tries I physically cleaned the CD (duh) & it worked!
Posted on Aug 06, 2010
    Problem Solver:
  • 10 Answers
You have lost or corrupter a system file or a corrupted registry, you can either remove your hard disk buy an adapter that will allow you to connect your small laptop hard drive to a pc via cd rom strap an manually drag & drop the files you wish to save into a folder on the desktop so you can burn & save them for reinstallation after putting a new system in your laptop or you can try using this registry tool .http://www.dll-repair-tools.com/ppc/download.php?con=Z2789 (hope for the best!)
Dell xp will not boot and has lines across the screen
I would say your Graphics Adapter is gone. Have you removed the HDD and tested it? Has it been Cleaned? Fan? vents? Heatsink? Overheating? If the graphics adapter is gone it's a death sentence in a laptop. You can try replacing the Thermal Paste and cleaning the Laptop out. But it may be to late.
Apr 11, 2013 | Computers & Internet
Had trouble with the computer freezing. Tried running chkdsk and the repair at start up. First time logging back on, I got a message that says shutting down windows to avoid major problems and now I have a...
Your operating system is corrupted with either a virus and/or missing drivers. That blue screen of death your receiving is because of missing or corrupted and the computer doesn't know what to do so it crashes. I would do a clean install of windows.
Jul 21, 2011 | Computers & Internet
When i turn on the laptop I get the message stop c000007b (bad image)
you probably need to re-install your opperating system with the OEM disk that you got when you bought the computer
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Blue screen on start-up saying 'stop: c000007b bad image' etc
The odds are, you will need to replace the HDD. Best odds for data recovery are to get a new drive and a universal HDD adapter (here is an example: http://www.amazon.com/Universal-Adapter-2-5IN-3-5IN-Sata/dp/B000QY9KIS)
Reinstall you operating system on the new drive then connect the old drive via the adapter and see if you can access the files you want to retrieve.
If that doesn't work, then you'll likely need to consult an expert like Drivesavers 800-440-1904 and see if you can afford a recovery of the data
Jun 13, 2009 | Dell Inspiron E1705 Notebook
Errr...sounds like fun.
OK well I would stop trying to get Windows back in working condition until after you backup your files.
The easiest way is to remove the hard drive from the system and place it into a usb enclosure.
Backup the files and then reinstall windows.
If you try the band-aid method you'll just end up wasting your time.
Hope this helps.
Jun 13, 2009 | Dell Inspiron 1300 Notebook
Blue screen
According to the Microsoft Help and Support
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your CD-ROM is failing or is not supported.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue: 1. Make sure that your Windows 2000 CD-ROM is clean and is not scratched. 2. If you have more than one CD-ROM drive, run Windows 2000 Setup from the other drive. 3. If these steps do not resolve the issue, you may have to replace your CD-ROM drive.
Jul 04, 2008 | Dell Dimension 1100 PC Desktop
Dell Inspiron 1300 Notebook Logo
7,796 people viewed this question
Alun Cox
