Question about Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive
Slave HDD not formatting correctly and displaying low capacity
Installed a Quantum Fireball lct15 30 as a Slave HDD in my PC which has a 40GB HDD Master. Creating a Primary Partition with DOS produced a total capacity of 9Mb FAT12 on a disk with 27Gb capacity. The disk formatted OK with 9Mb capacity and is quite usable but with very limited capacity. The Slave disk is shown in the Bios at run time with the limited capacity. How can I obtain the true capacity of the disk? The PC is operating under Windows ME
  • jdent75 Jan 06, 2009
    Thank you for your information unfortunately it did not resolve the problem - still getting 9Mb of FAT12. I should have pointed out that the HDD came from someones DVD recorder. I had assumed that its original format would have been over written by the Windows/DOS formatting process. Can anyone suggest a solution? The problem is bugging me!!
I've just solved this very problem on a lct 20 (40GB) which was showing as 9mb. The drive came from a dead series 1 Tivo DVR, which locks the drive capacity when it shuts down. The utility that solved it for me was qunlock (Google it - there's lots of Tivo upgraders who offer it) which runs from the dos prompt (make a dos floppy - or windows startup disk - and copy the program to it). Simply type "qunlock n" at the dos prompt where n is a number (0-3) that represents where the drive is (type qunlock/? for a guide). The important bit is to power off the computer afterwards! (Not ctrl-alt-del).
I also found the HDD Capacity Restore Tool from HDDguru.com which runs under windows, but although this reported the correct 40GB capacity of the drive, it did not successfully restore it for me.
Posted on Feb 05, 2009
    Sergeant:
    Novelist:
  • 190 Answers
If the bios does not see it at anything bigger than 9MB then the system will not do anything more than that. Did you install the drive on the same cable as your primary drive? If so make sure that the jumpers are correct. Try puting the drive on the secondary cable with nothing else on the cable. If you do have it on the secondary cable Im going to guess that you have a CD rom or DVD rom on the cable. You might try puting the jumpers on cable select for both devices remembering that the one on the end of the cable will normally end up being the master. Try just working with the secondary cable so that you dont have any issues with drive conflicts with the Primary master drive. Once you see the full drive amount in the bios then you can format the new slave. Fat 32 is the flie system of choice for Win ME so try the newer file system after you see the full drive size in the bios. I use a program called casper XP but you can get a free program from most drive manufacturers. I like the Western Digital Lifeguard program. Its easy to use and works on almost any drive. Hope this helps... Dale
Posted on Jan 03, 2009
  • Dale Barrett
    Dale Barrett Jan 06, 2009
    Does the hard drive show as anything more than 9 Mb in the BIOS? Not what it shows in DOS or Windows but the BIOS. If the BIOS doesnt show it as anything other than 9 Mb it will never show as anything other than that. If it does show as more than 9 Mb then what you need to do is use a drive setup software like I was talking about in my previous post. I ldont know what type of file system they use but it obviously will not work with your OS. What you are seeing in Windows / DOS is the balance of what was not partitioned when they set up the drive for the DVR. Please use a software that allows you to erase and then recreate a partition and you should be able to utilize the balance of your drive and format it with a fat 32 or NTFS partition. Just formatting from windows or dos will not do anything but blank out the partition that you allready have. It will not create or modify the partition. You need other software to do that. I hope this clarifies the process a little better. Hope this helps... Dale
I have a hdd quantum fireball lct 10 3.5" series with the serial number 973006916882 papxx power req 5/12v 600/900 ma. My question is about the capacity of this hdd since it is not written as I want to...
my hdd was install in IBM pc. Aftr that i am install my hdd in my assemble machine. My hdd is good condition.In BIOS HDD property is show perfect but when i want to format my HDD maybe fdisk or winXP CD my HDD is not work properly from this time. Please help me..........
May 20, 2010 | Computers & Internet
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Sep 11, 2009 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum fireball 40 not recognised as master
goto the quantum site and verify the jumper setting on the drive first
if correct then.. check your sata cable is good...
check the bios to boot options so the quantum is set to boot...
under boot options .. hard drives.. sort the drive to be the first to boot
Jan 04, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Fquantum fireball lct15 30 gb
After clearing CMOS and it still doesn't work, try to run FDISK on the drive. Delete partitions and create a new one. There could be a hidden partition which could be using the other hard drive space. Restart PC and then format again. This should allow you to use the full hard drive capacity.
Dec 11, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive Logo
451 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
