Question about Vector 995 Radar Detector
Beeps and says service required
Beeps and says ser required
  • 134 Answers
This message occurs if your V995 can't properly calibrate its internal circuitry for the antenna. As the message implies, you need to send in your V995 for factory service.
Posted on Mar 19, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Mis puertas no laquean
google translate
se trata de una pintura s?lida donde no se requiere cote clara
o ha pelado la capa transparente y necesita ser re hecho
tienen aire acondicionado no existan fugas en el sistema de
podr?a ser sin gas
My doors are not lacquered
What electric stereo inside no doors or air conditioning works
is it a solid paint where no clear cote is required
or has the clear cote peeled and needs to be re done
have air con checked for leaks in system
could be out of gas
Jun 19, 2016 | 2005 Isuzu Ascender
What does error code F3 mean?
not sure but here is the tech service manual GE JB960 Technical Service Manual
Feb 19, 2015 | GE Kitchen Ranges
I just brought my ps3 from the U.S to pakistan and set it up and all.Hooked it up to an old sharp t.v temporarily .Setup all the power supply even an adapter to convert 220 to 110V.but when i turned it on...
el problema puede ser su adatador de 220 a 110 pruevelo primero con un toma para 110 y revise con voltimetro si es de 110 v porque puede ser que no este funcionando del todo bien y si no prueve solo el play3 solo y si enciende problema resuelto es adatador
Oct 05, 2010 | Kitchen Ranges
When i turn the laptop on there is beeping noise like its not getting a good connection wwith the battery. it charges but when you turn it on it blinks beeps and turns off
Most likely this is an overheating issue. If the system is still under warranty you may send this system back to the depot center for repair.
Apr 24, 2010 | IBM Computers>Laptops Lenovo ThinkPad T60...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Vector 995 Radar Detector Logo
    925 people viewed this question
    Top Beltronics Vehicle Parts & Accessories Experts
    John Nolan
    Steve
    Jerry Greenberg
    Jerry Greenberg
    Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
