Question about Roper RAB2121KW Top Load Washer
Top Load Roper Washer does not agitate during wash/rinse cycle
When the washer is filled with water, the agitator works. I can put in one towell, and it does not work. What do I need to do to fix this?
  • Anonymous Jan 10, 2009
    THE AGITATE WORK WHEN FILL WITH WATER BUT WHEN CLOTH IS ADD THE TOP OF AGITATER DOES NOT WORK ONLY THE BOTTOM WORKS.
  • 126 Answers
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
Posted on Jan 02, 2009
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Roper RAB2121KW Top Load Washer Logo
394 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
