Question about Brother XL-5130 Mechanical Sewing Machine
I have a brother xl 5130 sewing machine. as im stictching, the front side stictches properly but in the back side the stiching is loose,
    President:
  • 2,976 Answers
There is a small screw on the bobbin holder. Tighten it SLIGHTLY. This will increase the bobbin tension.
Posted on Jan 02, 2009
  • gaynor polson Sep 19, 2013
    Very helpful although I didn't need to tighten it, I needed to loosen it slightly. Thank u
    New Friend:
Hi i have a brother model vx890 the top stitch seems to be fine but the one under is a complete mess can you please tell me what the tension should be so it doesnt do that
Posted on Dec 08, 2012
Need to no how to fix zig zag and straght stiche
sad to say without make and model we have a hard time finding what might be wrong and even a good photo of the front of the machine would help
Apr 02, 2015 | Sewing Machines
Toyota 8000 no longer sews zig zag, the needle can be moved to the side positions manualy
sounds like the cam or gear is damaged or broken, the machine needs to be checked
Jul 16, 2014 | Toyota Sewing Machines
I have a necchi 4575 and when I sew a straight stitch it will sew just fine and then for a few stictches it wil act as if its out of thread but then it will pick uop and sew normal for a few more stiches...
Sounds as though either the hook is out of time to the needle, or you have a bent needle. There are videos on Youtube that deal with sewing machine timing. Try a new needle, and make sure it is installed and seated correctly
Jan 05, 2012 | Necchi 4575 Mechanical Sewing Machine
My machine will not make a proper stitch. I've re-threaded it 3 times, but the stitch only occurs once in every3-4inches-I have just loose thread on my material.
have you tried changing the needle-if the needle has a flat side goes to the back of the machine-round needle the groove faces away from the shaft
check the top thread tension usually 3 to 5
Sep 10, 2011 | Brother XL-5130 Mechanical Sewing Machine
Machine will not engage in any other stiches except straight stiches
Remove the power cord then plug the unit back in. This should fix the problem.
Jan 08, 2011 | Brother XL-5130 Mechanical Sewing Machine
Lower thread very loose. can=t get even stich top and bottom?? thanks ruth hatch
Unthread and rethread the machine according to the manual. Sounds like you do not have it threaded right, make sure that your needle is inserted right (flat side faces away from you) and that it is not bent, replace it if you aren't sure if it is dull.
Sep 07, 2010 | Brother XL-5130 Mechanical Sewing Machine
The little thing that the needle goes into broke. How can i get a new one and what is it called? I have a Brothers machine XL 5130
it's called a needle clamp-check sewingpartsonline.com
on the left hand side click on brother parts
go down till you find your model number there is a brother xl 5130
it's close to the bottom of the page
please rate this with the thumbs in upper right hand corner
Aug 09, 2010 | Brother XL-5130 Mechanical Sewing Machine
Tension on reverse side of fabric is too loose-
Set the tension back to the recommended setting (in manual). This is usually around 4.
Always thread the machine with the presser foot up as this allows the thread to properly "seat" into the tension control.
Mar 23, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
178 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
