Question about Nikon N75 35mm SLR Camera
Black strip across the top of the picture
AFTER MY PICS ARE DEVELOPED, THERE IS A SOLID BLACK STRIP ACROSS THE TOP OF THE PICTURE..IS ABOUT 1 INCH WIDE..WHAT CAN BE CAUSING THIS..THANKS
  • Timm Chapman
    Timm Chapman May 11, 2010
    Were these flash pictures?
    It sounds like a flash synchronization problem. I believe the maximum shutter speed you can use when doing flash photography on the N75 is 1/90 of a second, therefore if you are taking a falsh picture and you have the shutter speed set any faster than 1/90, then the trailing shutter curtain will not have enough time to get illumination so only part of the photo gets exposed, and thus a black strip appears on the image.
  • 88 Answers
I can tell you exactly what is happening. This is probably either happening when you are taking a photo with a flash? The maximum flash sync your camera has is 1/125 or 1/60 of a second. If you set your shutter speed faster than that, you shutter closes too slow and creates that black strip. Put the shutter speed to 1/60 or slower and see if that happens. If you have a long lens on the camera, you have to have the shutter speed either equal or less than the focal length to shutter. 50mm lens=1/50 a second without a flash. Otherwise you could have a bent or broken shutter curtain blade. Maybe someone stuck their finger in there.
http://www.cameradr.com/
He can fix it if you blades are broken.
Posted on Jan 08, 2009
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Asus 1015P display has black strip across the top. do i need to replace display??
Boot to safe mode with networking, any change? The black strip, is it above the taskbar? If you place the cursor in the black strip, can you right click and open a menu? If no, try the driver, here: http://support.asus.com/Download.aspx?SLanguage=en&m=Eee%20PC%201015PEM&p=20&os=29
Feb 06, 2013 | Computers & Internet
For several weeks TV there was an 1 inch black strip across the top of the screen. Now the when you turn the TV and it switches back off
It could be because the cable cord in the back wasn't tightened all the way. This could also cause the screen to look fuzzy and un-clear.
Oct 10, 2009 | Philips Magnavox 20MT133S 20" TV
3 inch red area at top of screen and smaller blue area at bottom of screen
this would need a optical block. there would be no other way to solve this issue
Apr 18, 2009 | Televison & Video
Black strip blocking picture
Again, this is another case of " You need a qualified service technician to diagnose what is not working and replace those defective parts." This suggestion comes from an Electronics Service Technician for more than 40 years. I'm sorry I can help more. G. K.
Mar 28, 2009 | Emerson EWF2703 27" TV
RCA TruFlat Tv problem
YOUR TV HAS A RETRACE PROBLEM,FIND THE CAPACITOR 35V/100uf,1V/10uf AND COLDSOLDER FIRST THE MAINBOARD BEFORE YOU REPLACE THE COMPONENTS.
Jun 09, 2008 | RCA TruFlat 27F520T 27" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
HP flat screen tv
our hp flatscreen sometimes has a black strip across the top of the screen....resembling something "leaking"
Apr 30, 2007 | HP PE4200N 42 in. EDTV Plasma Television
Large Black Strip across the bottom of the (TV Cable) Picture
This happened to me too and i fixed mine by going into settings and for some reason my subtitles were turned on. turn it off and it should fix it.
Jan 14, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Nikon N75 35mm SLR Camera Logo
225 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
