Question about SanDisk Sansa e200 MP3 Player
Snadisk e200 won't work with computer
WTF!!!!!! this is my 5!!!! PROBLEM!!! AHHHHHHH!!! anyways don't mind my spaze but here's my problem. ok i'll turn on my mp3 and plug it into the computer nothing happens i tried changing the usb modes but nothing works !!! WHAT"S WRONG AND HOW DO I FIX IT!!!
You could try going on device manager and uninstalling it. Then go on control panel and go on add hardware wizard. This will reinstall the device. If it comes up with a dialogue box saying that theres a problem with the registry on the mp3 then it will be the mp3 player that has the problem. Otherwise it should work.
Posted on May 23, 2007
L have an Elna 1010 that has never been plugged in. Do I need to oil it before I use it? Is it ready to go after all these years?
check in the manual and see if it's self oiling or not,, some
machine parts are soaked in oil from the factory & don't need
to be oiled other machines have to be oiled,,if the manual doesn't
say then contact elna customer service and ask them.
I won't promise the machine will work or won't work if it's been
sitting for years ,sometimes the grease can become sticky and
hard.
you'll be able to tell as soon as you start sewing, make sure you
read the manual completely, that way you know what the machine
will do and what it won't do.
always use the proper needle for the fabric
and the proper foot
if you go over a seam and the machine seems to struggle, take your
foot off the foot pedal and use the handwheel to move the needle
manually over the seam, that way you don't bend a needle and cause
the machine to jump time.
also make sure to have a comfortable chair and good lighting and
a good seam ripper just in case of a mistake.
if you get frustrated while sewing, get up and walk around, that can
help clear your mind, I've had to do that plenty of times and I've
been sewing for 30 years.
if you don't have a manual send me a comment and I'll try to find you one.
there are several websites that have tutorials and other things for
a quilter,,
happy sewing
Oct 19, 2012 | Elna 2007 Mechanical Sewing Machine
Burned cd's on computer will not play on other players
Ok, here's are the likely culprits:
  1. One possibility is that you are using rewritable CDs (CD-RW), which will not work on most players. You need CD-Rs for that.
  2. Make sure you are burning an audio disk, not a data disk.
  3. In order for a disk you made to work on another computer or another player, you need to finalize the disk. You should see that information listed in the CD burning software in the options. If you can't find that information, comment and I'll tell you how to do it for your player.
  4. If these don't work, I would see if another brand of CDs do work. Some brands (Memorex comes to mind) can be a little finicky where they work. I've had good luck with Verbatim, but there are other good brands.
Hope this help you. Good luck!
Mar 31, 2012 | Computers & Internet
97 jetta doors won't lock
I assume the doors can be manually locked. The problem is in the electrical circuit. That means anything from a faulty switch (the lock / Unlock button) to a loose connection. If both switches don't work then look for a blown fuse. If one switch works and the other doesn't than remove the switch and inspect its connection. If it's ok then check the switch. If both switch and connections are OK then you'll have to remove the door panel and access the lock mechanism.
Dec 11, 2011 | 1997 Volkswagen Jetta
I have the sportster rewind 2 i did not pay my bill sirius shut it off ..... ok no prob here.......... trying to re activate sirius said i need a new radio ;( it shows i have 3 bars of service on the...
If you don't pay your bill, you'll need to buy a new radio, since they'll lock it out of the network. You *might* be able to have it activated online, so try that out before giving up. If that won't work, then just sell it for parts on eBay, if it's a functional (but banned) radio, you'll probably get $20-$40. Make sure you mention it's banned.
Sep 06, 2011 | Sirius Sportster 5 Satellite Radio...
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
My env2 is having spazes the ok button and the
take this to the verizon repair store nearest you and explain your problem..when mine starting freezing up it was just a download of new software it needed because of a glitch when they first came out.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
The charge doesn't work!!!!!
you will have to recover the flash i sounds like it´s preatty dangerus ..you may brick the player so it never work again ... and you will need ubuntu ... search on google you will find howto flash a e200 preatty fast you should find it anyway..
im sorry i can´t give you a guide rigth now because i don´t got the time but it really sounds like it is the flash..
Feb 14, 2008 | SanDisk Sansa e250 MP3 Player
I JUST GO MY sansa e200 TWO DAYS AGO AND I OPENED IT YESTERDAY
press and hold the power button for 15 -20 seconds to turn off
Apr 08, 2007 | SanDisk Sansa e200 MP3 Player
Eeee ..Need Help >.<
The songs might have a virus in it or they might be corrupted. Reformfat the sandisk by going into MY COMPUTER and then finding the devices icon and right click on it and click on FORMAT.
Jan 18, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
