Question about Philips 55PP9401 55" Rear Projection Television
No picture No sound
I have a phillips 55pp9401 That was given to me It has no picture or sound The light comes on in the front the projection board lights up My friend had a tech look at it he forgot he said was wrong with he thinks they said it was the high voltage converter he said it would cost about $500 to fix it
  • 1 more comment
  • gllanier3 Jan 02, 2009
    yes i do
  • gllanier3 Jan 03, 2009
    The TV has hitachi boards I found a high voltage converter bw00634 They have 2 Hitachi 75.00 and phillips 147.00 is there any differance in these two? Can I use the Hitachi The fly back is on a hitachi defection board jk07112
  • gllanier3 Jan 05, 2009
    thank you
    President:
  • 1,990 Answers
Welcome to Fixya! Yes That would be the Problem. Clear and Simple. Not much else that you can do with it till then.
Posted on Jan 02, 2009
  • 10,594 Answers
Do you have service manual of this TV? Looking into schematics, measuring voltage and testing few parts will guide you to locate fault .
  • Shahid Electronics
    Shahid Electronics Jan 02, 2009
    ok,
    You need to check Power Supply output voltage, specailly +B volts and then horizontal deflection section.
    Horizontal defelction section is most inmportant area in a TV. check +B volts should be supplied on H-Out Transistor and H-Drive transistor. If volts there, then H-Oscillation circuit is involved here.
    There is possibility of protection activation in TV as H-deflection or Vertical deflection failure cause this activation. Over Current consumption (FBT one of part) over volts etc are reasons of protection ON.
    Shahid Electronics Jan 03, 2009
    You should use Philips recommended fly-back though its made by Hitachi.
    TV Manufacturer  like Philips, Hitachi, Sony etc order parts to vendors as per their requirements and vendor can be any other company but its not necessary that subject part made of Company-A for Company-B product can be used in Company-A product too.
    I'm not sure that my point conveyed properly.
Phillips tv power light flashing, clicking noise
There is some shorted component/s at its main digital board. Troubleshooting this stage circuit is a skilled one. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 05, 2013 | Televison & Video
Intellisense adjustment not working
It will not work if the convergence circuit is not functional--it is indicated here it is phillips 55pp9401?
Mar 24, 2012 | Philips 55PP9401 55" Rear Projection...
Orange faces and lost of red on screen
You got a convergence board problem that would need to be repaired around $150 bucks.. This would need to be done by a repair technition as there are things that need to be reset inside once the new part is in place.
May 24, 2009 | Philips 55PP9401 55" Rear Projection...
No picture sound ok
IF IT WAS WORKING OK BEFORE CHANGING FLUID. YOU MAY HAVE SPILLED A SMALL AMOUNT ON CHASSIS. SOMETIMES IT IS VERY HARD TO SPOT.
Dec 14, 2008 | Philips 55PP9401 55" Rear Projection...
PHILLIPS 559401 REAR PROJECTION TV
ok the problem u have is that u need to have a scope and a volt meter to test the circuits what i would do is check and see if u have a 130 v on the horiza output transistor first. but if u dont have any meters there is nothing u can do to fix the problem. and just rember that phillips allwas wonts u to buy the board that is y it is not cheep to repair a magnavox or phillips sometimes u can buy another tv lot cheaper. i hope this help some what marty.
Oct 13, 2008 | Philips 55PP9401 55" Rear Projection...
SET WON'T POWER UP
i hate to tell u but maganvox bigscren are not ment to be repaired so now i said that i need the model number on the tv to help u but most all magbavox phillips and sylvania tvs most of them are big screens u have to buy the hole board from magnavox and it cost as much as the tv did. but i will try and hp u if u get me the model number and i need to know if u turn the set on and wait 2 mins and trun it off do u see and thing on u screen at all please let me know marty
I have no picture coming out of my blue picture tube
ok 2 things could be wroung one is u have a bad crt board one way to find out is swap the blue crt board with the red crt board and see if the blue comes up and now u have no red. now u can not swap it with green the green crt board is allways by it self noe if that does not work and u still have no blue it could be the picture tube or something from the video board that is blaking it out and without a scope u cannot trace it but if u are lucky it will be the crt board hope this helps u
Sep 05, 2008 | Philips 55PP9401 55" Rear Projection...
Screen missing
you will need the replacement screens. Phillips doesnt make them anylonger, they are exspensive. But you can get one by leaving a email at the following link with the model number of your set and what youre needing.
http://servicemanuals.vstore.ca/
Jul 03, 2008 | Philips 55PP9401 55" Rear Projection...
How doi adjust convegence manually on phillips 55pp9401
Order service manual from partstore.com ..........
procedure is complicated..............T.
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
