Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Black marks My Equator occasionally leaves black marks in the pattern of the drum holes on clothes. I stopped using the drying cycle and the problem subsided, then began again regardless of cycle. There is no pattern to when it happens. These marks might be burns. They do not fade or wash out.
  • 883 Answers
Throw a clean pair of old sneakers in the dryer with the clothes. this should not allow the clothes to stay in one place during the entire dry cycle
Posted on May 25, 2007
SOURCE:
Our tumble action front-loader washer just recently started leaving black marks in the pattern of the holes on the inside of the washer drum- We ran it twice without anything in the washer, and it still...
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Aug 03, 2011 | Frigidaire 14 Cycle Tumble Action Washer
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Maytag dryer is leaving black marks or rings on clothes
    If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
    Aug 01, 2010 | Maytag Dryers
    The dryer is squealing and leaving burn marks on the clothes
    Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
    When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
    Same thing happens when drum slides wear off (black marks are left on clothes)
    Aug 15, 2009 | Frigidaire Dryers
    Problems Drying Clothes
    That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
    Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
    Loud noise in spin mode and black spots
    This is joyce
    How old is this unit?
    this can be costly to fix, it may not be worth the cost, may just replace, the barrons in drum sounds like they are shot and the oil is from the inside gasket, my friend at work had the manufacture to replace her dryer because of this. you may want to call them if your unit is not to old, they also may have recall on your unit so call and make sure of this before you discard unit. go to webb site I have never heard of your unit so I am not familar with who makes this unit.
    thanks
    please grade me at end of session
    joyce
    Feb 04, 2009 | Equator EZ 3612 CEE Front Load...
    Burns clothes!
    http://www.fixya.com/WrnModule.aspx?prdid=42469
    cheak this out once
    Feb 08, 2008 | Equator EZ 1500 Front Load Washer / Dryer
    Washer/Dryer not drying
    is your dryer a conderser type
    does it have a tank that you have to empty at the end of cycles
    if it does the filter that condensers the water from drying cycle
    if that is blocked it will not work
    Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
    Black marks on clothing at completion of drying cycle
    Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
    Jul 06, 2007 | LG DLE2514 Electric Dryer
    Tumble Dryer
    how do i fit felt gasket on front of dryer?
    Oct 10, 2006 | Zanussi TD4100W Electric Dryer
    Equator EZ 3612 CEE Front Load Washer/Dryer Logo
    383 people viewed this question
    Top Equator Washing Machines Experts
    Heartland Ho
    Level 1 Expert
    Gerry Harvey
    Gerry Harvey
    Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
