Cars & Trucks Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear power door not working
When actuated, the lift motor can be heard running for a brief time, but does not lift the door. Suggestions? Could it be not engaging? There is a click, then the motor can be heard, but nothing else happens. The door CAN be opened manually.
  • Anonymous May 11, 2010
    when you press button, the gate unlatches then stalls there while motor runs?
Anonymous
Level 2:
  • Expert 137 Answers
  • Posted on Jan 22, 2009
Anonymous
Expert
Level 2:
Answers
137
Questions
0
Helped
82174
Points
442
Check the gate suports.. its very common for them to rust at the ends and cause them to bind that will not allow the gate to lift on its own. a click or pop may be heard when the gate is opened or closed.. also if the supports are working right the gate actually moves away from the body when the latch is released. if its stays against the body then try the supports for the gate
2005 chevy trailblazer rear lift gate does not lock but the rest of the doors and rear window lock
Door Lock System Components
The power door lock system consists of the following components:
• Driver Door Module (DDM)
• Passenger Door Module (PDM)
• Liftgate Module (LGM)
• Door lock relay
• Door unlock relay
• Body Control Module (BCM)
• Reversible door lock actuators in each of the doors
• LR/RR LOCKS 10A fuse (relay supply voltage)
• Door lock switches in driver and passenger doors (switches are integral components to the DDM and PDM)
Power Door Lock Operation
The power door lock switches are integral components of the DDM and PDM. The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The modules which activate the power lock motors are:
• DDM (driver door lock actuator).
• PDM (passenger front door lock actuator).
• BCM (both rear door lock actuators).
• LGM (liftgate door lock actuator).
Could be a lot of thing's causing it not to work . The way we would diagnose is to hook up a scan tool an look for a DTC - diagnostic trouble code in the lift gate control module first ,no codes ,look at a wiring diagram an test voltages at the lock actuator ,switch etc... Also look on scan tool data to see if the lock/unlock command is getting to the lift gate module .
What relay under the rear seat in a 2007 chevy trailblazer run the rear lock and wiper motor?
None < LGM - liftgate control module inside the lift gate does .
Rear Wiper/Washer System Components
The rear wiper/washer system consists of the following components:
• Rear window wiper motor
• Rear washer pump
• Rear wash relay
• Rear wiper/washer switch
• RR WIPER Circuit Breaker 15A / ENDGLASS REG Circuit Breaker 30A
• WASH 20A fuse
• Body control module (BCM)
• Liftgate control module (LGM) / End gate module (EGM)
Your best bet , take it to a qualified repair shop. You have no idea of the complexity of these system's . Communication network between modules etc..... Could have DTC'S diagnostic trouble code's stored in the liftgate control module . An auto parts stores can not read these codes .
The DDM, PDM and LGM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
1helpful
What fuse is it for rear hatch actuator 99envoy
One fuse powers all door lock actuators . The other door locks work ? if so it's not a fues problem .
The following locking functions are included on the vehicle:
• All the doors unlock -- All the doors will unlock, including the endgate/liftgate, when any power door unlock switch is detected. The passenger doors lock directly by pressing the lock switches. The driver door unlocks by the BCM using a driver door unlock relay.
• All the doors lock -- All the doors will lock, including the endgate/liftgate, when any power door lock switch is activated. All the lock actuators will activate directly from the power door lock switch (external to the BCM).
• The end/lift gate lock switch -- All the doors will lock or unlock from the end/lift gate lock switch
You probably have a bad lock actuator
How do I open the back doors of my polo, comfort control unit does not work
Not an expert but you seem to have a problem with the actuator units on the rear doors I hear this is a common problem with VW Polo some times it is the actuator not lifting the lock far enough or it is a total failure of the rear actuators this can be fixed if it is an adjustment on the lifter but it involves stripping the door to adjust the lifters or to replace the units first you need to find out if they are doing anything and if you are getting power to the actuators most times it is a job you can do yourself or it is a trip to an auto electrician.
Door locks not working
could be a wiring short, but if you hear the lock motor moving i believe the lock actuator has broken free. the rivets break free at times and i've used screws and washers the reattach the actuator in place without having to pull apart the door. try to see if you hear 1 doorlock at a time. if when you press the button, the motor sounds and theres movement thats your problem. if you press and theres no motor then you either have no power to the motor or its bad. current tester to the switch will tell you either way.
1helpful
2answers
2002 TRAILBLAZER no rear heat. Rear fan works only blows out of lower vents. Will not switch to upper vents even on AC. Have heard clicking sounds from somewhere in the rear. Radiator is full. This...
Hello! One of the Blend Door Actuators is defective...There are three different Actuators...See picture #1...I would suggest that The Mode Door Actuator is defective...It is DORMAN Part # 604115...Cost = around $50..It is on the lower left side of the pictured HVAC unit....The part is shown in picture #2....After replacing The actuator...Pull the heater fuse...Start the engine...Run for 45 seconds...Turn off key...Replace fuse...This allows the computer to learn the new part...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
6helpful
2answers
When I turn the heat on the drivers side only kicks out cold air while the passenger side kicks out hot air...
The blend door is not working right or the in car air temperature sensor is faulty.
Removal & Installation Air Inlet Door Vacuum Motor To Remove:
  1. Remove the instrument panel.
  2. Remove the air inlet door motor mounting screws. CAUTION
    Do not attempt to bend any part of the air inlet duct door lever.
  3. Rotate and remove the air inlet door vacuum control motor.
To Install:
  1. Rotate and install the air inlet door vacuum control motor.
  2. Install and tighten the mounting screws.
  3. Install the instrument panel.
Defroster Door Vacuum Motor To Remove:
  1. Remove the passenger air bag module from the instrument panel.
  2. Disconnect the vacuum line and remove the mounting screws. CAUTION
    Do not attempt to bend any part of the defroster airflow mode door lever.
  3. Rotate and remove the vacuum control motor from the defrost door lever.
To Install:
  1. Rotate and install the vacuum control motor on the defrost door lever.
  3. Connect the vacuum line to the vacuum control motor.
  4. Install the passenger's air bag module.
Floor Console Register Duct Vacuum Motor To Remove:
  1. Remove the floor console.
  2. Remove the right-side instrument panel insulator.
  3. Working from the passenger's footwell, disconnect the vacuum hose.
  4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
    Do not attempt to bend any part of the floor console register duct door lever.
  5. Rotate and remove the vacuum control motor from the floor console register duct door.
To Install:
  1. Rotate and install the vacuum control motor on the floor console register duct door.
  3. Connect the vacuum hose to the floor console register duct vacuum control motor.
  4. Install the insulator under the dash.
  5. Install the floor console.
Panel/Floor Door Vacuum Motor To Remove:
  1. Working through the driver footwell, remove the two screws and the shield. CAUTION
    Do not attempt to bend any part of the airflow mode door lever.
  2. Label and disconnect the two vacuum hoses.
  3. Remove the mounting screw.
  4. Lift, rotate and remove the panel/floor door vacuum control motor from the door lever.
To Install:
  1. Install the panel/floor door vacuum control motor on the door lever.
  2. Install and tighten the mounting screw.
  3. Connect the vacuum hoses in their original positions.
  4. Install the shield on the vacuum motor.
Auxiliary Air Distribution Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel access panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Remove the auxiliary air distribution blend door actuator screws.
  3. Disconnect the auxiliary air distribution blend door actuator connector.
To Install:
  1. Connect the auxiliary air distribution blend door actuator connector.
  2. Install the auxiliary air distribution blend door actuator screws.
  3. Install the right rear quarter trim panel access panel.
Auxiliary Temperature Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Disconnect the temperature auxiliary temperature blend door actuator connector.
  3. Remove the temperature auxiliary temperature blend door actuator screws.
  4. Remove the temperature auxiliary temperature blend door actuator.
To Install:
  1. Install the temperature auxiliary temperature blend door actuator.
  2. Install the temperature auxiliary temperature blend door actuator screws.
  3. Connect the temperature auxiliary temperature blend door actuator connector.
  4. Install the right rear quarter trim panel.
--- In-Car Temperature Sensor Removal & Installation To Remove:
  1. Remove the instrument cluster finish panel.
  2. Disconnect the in-vehicle temperature sensor connector.
  3. Disconnect the in-vehicle temperature sensor aspirator tube.
  4. Remove the in-vehicle temperature sensor screws.
  5. Remove the in-vehicle temperature sensor.
To Install:
  1. Install the in-vehicle temperature sensor.
  2. Install the in-vehicle temperature sensor screws.
  3. Connect the in-vehicle temperature sensor aspirator tube.
  4. Connect the in-vehicle temperature sensor connector.
  5. Install the instrument cluster finish panel.
2helpful
2answers
My rear lift gate does not unlock. The rest of doors do, it is a four door. Also my front drivers side window does not roll up or down. Here again JUST the drivers window, the rst roll up and down. Could...
They are not related ...
The lift gate locking mechanism can be accessed by removing the interir trim pannel on the gate ... and locating the locking actuator and replacing it...
The same can be done for the power window motor ... remove the interior trim panel and replace the power window motor...
Hope I helped !!
Actuator removal
please rate as solved if this is what you need. You will need to borrow a heavy duty riveter from autozone or wherever you buy the lock cylinder from.
Removal
  1. NOTE: The rear door window glass must be completely raised.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the rear door trim panel. For additional information, refer to Section 501-05 .
Trim Panel —Rear Door, Expedition Removal
  1. Remove the power window switchplate (14524).
  1. Disconnect the electrical connector.
  1. Remove the rear door handle trim cover.
  1. Remove the rear inside door handle.
    • Remove the door handle bolt.
  1. Remove the rear door trim panel screws at bottom of panel.
  1. s2j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the rear door trim panel, do not pull directly outward.
    Lift upward and then outward to remove the rear door trim panel (27406).
  1. Remove the rear door watershield.
  1. Disconnect the power door lock actuator electrical connector.
  1. Drill out the power door lock actuator rivet.
  1. Remove and discard the screws.
  1. Remove the power door lock actuator.
    • Disconnect the power door lock actuator rod.
Installation
  1. NOTE: Use new screws when installing the rear door latch.
    To install, reverse the removal procedure.
    • Use Heavy Duty Riveter to install the new rivet.
2006 Tahoe Z71 Lift Gate Will Not Unlock With Remote
Take the liftgate inside panel off an check the wiring , connections etc....
rear door hatch lock repair GMC Chevrolet
chevy tahoe lift gate not opening
The liftgate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the liftgate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The liftgate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a liftgate lock function has been received by the BCM. The BCM will then ground the control side of the liftgate lock relay. This energizes the relay and allows voltage to be applied to the liftgate lock actuator lock control circuit. Since the other side of the liftgate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the liftgate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and liftgate will unlock.
The BCM also runs diagnostics on the liftgate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the liftgate lock circuit and that the liftgate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following
Power Door Locks Inoperative - Endgate/Liftgate
Schematic Reference: Door Lock/Indicator Schematics
Connector End View Reference: Power Door Systems Connector End Views
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Activate the door lock switches to the lock and unlock positions.
Do both rear passenger doors lock and unlock?
YES - Go to Step 3
NO - Go to Power Door Locks Inoperative
Did the liftgate lock actuator lock and unlock?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 4
Disconnect liftgate door lock actuator.
With a test lamp connected to a good ground, probe the door lock actuator lock circuit at the door lock actuator harness connector.
Activate a door lock switch to lock position.
Does the test lamp illuminate?
YES - Go to Step 5
NO - Go to Step 7
5
With a test lamp connected to a good ground, probe the door lock actuator unlock circuit at the door lock actuator harness connector.
Activate a door lock switch to unlock position.
YES - Go to Step 6
NO - Go to Step 8
6
Inspect for poor connections at the harness connector of the door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 10
NO .. Go to Step 9
7
Repair the open door lock actuator lock circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 10
8
Repair the open in the door lock actuator unlock circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 10
9
Replace the liftgate door lock actuator. Refer to Door Lock Actuator Replacement in Body Rear End.
Did you complete the repair?
Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
