Question about Brewmatic 1033510B Stainless Steel
Machine is leaking
I have had the machine apart several times and I discovered that I need an o ring.
where do you get the parts? I live in British Columbia, Canada.
    President:
  • 2,976 Answers
You can buy 'O' rings at Most industrial supply companies. A lawnmower shop will also have some, if you need something real small. If all else fails, you can make one out of a wide rubber band. Put a hole in it to fit around where it goes and trim it to fit with a finger nail clipper. I've used this method to fix a chipper and a lawnmower carburator.
Posted on Jan 02, 2009
How to extend ring time before answer machine cuts inExtend ring time
you're gonna need to go to your menu options to change the number of rings. Google your model and then look under manual. Perhaps this is it: http://www.home-phones.co.uk/assets/uploaded/documents/384_BT_Synergy_5500_userguide.pdf
Nov 04, 2014 | British Telecom Synergy 5500 Trio 4Line...
H-104 developed massive leak!
The water is under pressure so any leak can become serious quickly. The fault can be attributed to inadequate parts but also the ring may have been improperly seated during installation.
Feb 23, 2014 | Everpure ADC RV Water Filter Cartridge
Leaking at front door steel ring snapped where do u get parts from
The new part is simple to fit below is a link to a local retailer who will be able to supply the part.
Link:
Mar 11, 2012 | LG Washing Machines
Leaking under machine
If it's leaking you need a new door seal. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520777
Taking it off is kind of hard. You have to take the top off, the door lock off, and the front off, and the screws out of the bottom on the drain filter. Make sure it's not leaking from the bottom by putting water in the tub. Check to see if the gasket is torn on the inside by removing the spring ring with a flat head. Find your way to get it back on after replacing this part. The rings are tricky.
Jan 19, 2012 | LG WM-2277HW Front Load Washer
I have a Lavazza Point Expresso Machine and it started leaking water out of the front. I believe it needs a gasket, but can't seem to get the parts to come off to get to it. I have used an Alen Wrench,...
When replacing the o-rings inside the boiler the operation should be carried out by a certified technician for these machines. When the boiler is dismantled it is recommended that all o-rings and springs in the boiler be replaced as these are ware parts. When the boiler is apart this is also an opportune time to do some manual cleaning to the internal parts. This is an easy task but as I said before must be carried out by a certified technician. Special tools not readily available to homeowners are required to rebuild the boiler once dismantled. I am sure there are many repair facilities around but location wise I am not sure. I have heard that espressozone.com are nice and will do repairs. Perhaps try them. You may also try contacting a lavazza rep and they may be able to point you in the right direction.
Apr 09, 2011 | Lavazza Espresso Point Capsule Machine
How do i find out the call list of people who have phoned
Firstly check with BT(i`m presuming this) that you have activated caller display, it is free but you have to request it.
Your answer phone (you don`t say which) may have the ability to store numbers, and /or depending what handset you have this could tell you the numbers of people who ring.
There is only one way to discover the last no, that is by ringing 1471.
Oct 23, 2009 | British Telecom Lands Phones
Black smoke from exhaust
i know for a fact that the oil is getting strait out in your exhaust system...
a common cause is a failiure of the pcv valve wich is located on the intake manifold.
to check her, just take it out of the manifold and shake it in your hand...
you should be able to hear a clicking sound out of it. if not it is done...
Apr 28, 2009 | 2001 Ford F350 Super Duty SuperCab
Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Brewmatic 1033510B Stainless Steel Logo
82 people viewed this question
Top Brewmatic Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Brewmatic Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
