Question about Amana AGR5735QDS Gas Kitchen Range
Oven temp reads in C and I need F
How can i change my oven settings back to Farenheit? It has somehow set to celcius.
    Scholar:
  • 111 Answers
To change the setting, press and hold the Cancel and Bake
pads at the same time for three seconds. A single beep will sound and the current setting will be
displayed (°F or °C). (If no change is made, the range will
return to the existing setting after 30 seconds.)
To change the setting, press the UP or DOWN pad. Press again to
return to existing setting. Wait five seconds and the setting
will be complete. From page 11:
http://shop.amana.com/assets/pdfs/literature/8113P483-60.PDF
Posted on Jan 02, 2009
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range how do I change the temp setting from celcius to farenheit
refer to page 9 in your owners manual. press and hold the boil button until you hear a beep. this enables you to change it from f to c or c to f.
Aug 27, 2017 | Whirlpool Kitchen Ranges
I have a whirlpool accubake oven that is stuck on the celcius temperature and I don't have an owners manual and I need to reset it to farenheit. Please help!
To switch it to Farenheit..press and hold the BROIL button for up to ten seconds and the display of the broil temp will change from 500 to F then push clear/off button...if later on it needs to be switched back to C do the same thing
GENE
Aug 28, 2011 | Whirlpool Ovens
How do you switch oven temp settings back to Farenheit from Celcius
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417008en.pdf
bottom of page 9
Mar 02, 2011 | Frigidaire FEF364DQ Electric Kitchen Range
Whirlpoo stove is in celcius now how can i change it back
You must go through the 'menu' on the control panel to set preferences and set to Farenheit
Aug 01, 2009 | Whirlpool SB160PEE Gas Single Oven
Convert temp control from celcius to farenheit
Yo can do it the long way:
°F to °C Deduct 32, then multiply by 5, then divide by 9 °C to °F Multiply by 9, then divide by 5, then add 32
Or you can do it the easy way and go to:
http://www.wbuf.noaa.gov/tempfc.htm and use the converter.
Thanks for using Fixya.
Mar 28, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
This sounds like a Jacuzzi. This is hard to describe. In the control box, on the circuit board, in the upper right corner there is a small bunch of pins in 2 rows 5 or 6 in length. one set of pins have a black jumper on them, remove the jumper and temp should go to farenheit. Turn off power to spa before doing this.
Mar 28, 2009 | Home
How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change:
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
Nov 07, 2008 | Whirlpool Ovens
Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Apr 06, 2008 | KitchenAid KGST307 Gas Kitchen Range
Changing the temp. from Celcius to Farenheit
The correct formula is to take the Celcius degrees and multiple by 1.8 and then add 32.
or
F = (C x 1.8) + 32
Regards, Wayne Parrish
Jan 09, 2008 | Sharper Image SI686 Clock Radio
Amana AGR5735QDS Gas Kitchen Range Logo
326 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
