Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Green light flashing
Yes I have waited for hours and nothing changes. Green Light flashing on front panel of TV. TV will not turn on.
Green Light has been flashing for hours!
  • 2 more comments
  • kaay_lo Jan 02, 2009
    I am not really skillful in this kind of stuff. How much would it cost me to have someone come out and fix something like this? Do I call Mitsubishi? Any suggestions? I am in Southern California area. On the West Side. Los Angeles, Santa Monica
  • Anonymous Jan 02, 2009
    Same problem. Help
  • dremenap Jan 02, 2009
    I'm having the same issue. No pic, nothing. I left it unplugged for the night and nothing changed.
  • dcoleman7 Jan 09, 2009
    A couple of years ago I had the same problem. Had a repairman out and he replaced 4 capacitors at a cost of about $400. Last night the same thing happened again. If I could get instructions I would try and repair it myself.
    Thanks
    Dave C
  • 505 Answers
This means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Posted on Jan 02, 2009
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
TV won't turn on
Count the flashes. Then we can help.
May 21, 2009 | Sony 40 in. LCD HDTV
Tv will not turn on
hi,
this seems to be capacitor problem, so replace capacitor(s) that are burnt out!
Mar 20, 2009 | Samsung LTN1535 15 in. HD-Ready LCD...
Was this happening before the lamp problem? What usually causes this is 4 capacitors on the DM module inside the TV. But usually this will happen over a period of time.
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
