Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Disconnecting the 4 way switch on a outdoor spa
There seems to be a short in this switch. I do not use the spa side switch. How do you undo the wiring to the switch? Can I cut the wire in two since it is a low voltage switch?
    Problem Solver:
  • 7 Answers
You can cut the wires, then make to tape/seal them all separatly from each other so they don't touch. Or you can open up the control panel and disconect the wires from the circuit board.
Posted on Jan 06, 2009
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
Software to rest wap 1001 to default
"Its easy but you have to open the unit. Undo the 6 screws holding the base one
Slide out the internals
You will see spot on the board labels SW for switch but no switch soldered to it.
While the power is on, use a wire to short the 2 contacts of the switch that stand out alone. IE. not the 3 together. Hold this short on for about 5 seconds then the led should blink
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual." -fixyaMarkoa34a5098-f669-488f-a6a9-3f02c825de75.jpg
Nov 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Gmail.comi forget password wep-1001
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual."-fixyaMarko6b1bc267-b1e9-46c6-83c5-0f9087420f37.jpg
Sep 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
How to install presure switch
Hi.
The pressure switch is located behind the control panel. Its unction is determining the level of water in the washer.The switch looks like a round shaped plastic switch connected to wires and to a long thin rubber hose. To replace the switch disconnect power. Undo the screws holding the control assembly. Remove control assembly cover. Disconnect wires from switch and undo the screw holding the switch. Pull out the rubber hose from the tub and perform operations in reverse order to install the new part.
The switch is part nr.4 in diagram below. Click on the picture to enlarge:
Jul 07, 2011 | Maytag MTW5700TQ Top Load Washer
I have installed a 2-way dimmer switch in my dining room. I was able to install it and it works great. However, on the other side of the wall where I installed the switch, I have another single way...
If I understand correctly new dimmer is in different box than outdoor switch.
And outdoor switch controls different light than new dimmer.
Both new dimmer and outdoor light are on same circuit breaker, and that breaker is not tripped.
Outdoor problem could be related if loose wire inside dimmer box also feeds over to outdoor switch. More below.
Here's how I would troubleshoot problem.
1) Check outdoor bulb(s). This step can be big time saver.
2) Pull outdoor switch out of box a bit so you can see and test wires.
3) If wires are pushed into quick connects located on back of switch, these connects get loose. Moving switch usually causes loose wire to connect again, so turn switch ON-OFF and see if outdoor lights work. Sometimes switch works fine after quick connects reconnect. If quick connects are bad, use tiny screwdriver in slot next to connect-hole to release wire. And then connect wire to screw terminals on switch. Or replace switch.
4) Turn switch to OFF, use tester and test both screws on switch to bare ground wire. Tester should light up on one screw. If tester does not light up, then switch is not getting power, and that wire has to be tracked back to see where short is.
a) Look if one of the black switch wires is connected to other switch, or connected to other black wires inside same box. This wire might have come loose.
b) Look at white wire inside same box and make sure they are twisted together and covered with wire nut.
c) Now here is where dimmer could be related ... if white wires are joined together in dimmer box, they could have come loose if they were not properly twisted together and covered with wire nut.
http://waterheatertimer.org/How-to-twist-electric-wire.html
5) Turn switch to ON and test again. Tester should light up on both screws. If switch does not light up on both screws, then switch is bad. Replace switch.
Add a comment if you need more help.
Dec 01, 2010 | Leviton Decora Light Dimmer Switch
I forgot password and want to reset to factory default ... I can't seem to logon to my level one wap 1001 ap. I can't seem to logon to my level one wap 1001 how can i reset password or factory defaults
thanks, I open it and I short 2 contacts [sw1] but after4 shorting its changing the IP only 192.168.1.20 but may be the name and password remain same, bcoz i try to login with defaults user name : admin and password : balck but its fail.
so can u help me to reset it again ?
thanks
Nov 26, 2010 | Levelone Level One FreeCon 802.11G Outdoor...
Jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Oct 28, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
171 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
