Question about Whirlpool GHW9100L Front Load Washer
Banging while spinning and disintegrating gasket
A couple of days ago, my Whirlpool Duet washer (GHW9100LQ1) started making a loud banging while spinning as though the load was out of balance. In addition I have found a white residue on clothes that were washed in a dotted pattern matching up with the holes inside the tub. And on top of that there is a gasket at the front of the tub (not the boot) that seems to be disintegrating, leaving fragments in the washed clothes. I have also found a fine gravelly discharge in the outflow and similar material was in the pump filter when I cleaned that out.
  • sxb1 Jan 08, 2009
    For what it is worth, a Whirlpool-recommended technician confirmed this diagnosis. Whirlpool was willing to waive the shipping charges for the parts.
  • sxb1 Feb 25, 2009
    I should have added this comment a while ago. When the technicians who did the work tore down my machine, it revealed that if was indeed the tub support rather than the bearing that had failed. The repair was done for the cost of labor as the parts were under warranty. There was some talk of my being charged for shipping the parts (inner and outer drum), but Whirpool eventually waived those fees. I'm just as happy that I had someone else do the work. It ended up being a 2-person job, but they were able to complete the work in under 2 hours. They appreciated that I had cleared them a large work area in our laundry room as the whole machine really does have to come apart.
  • 16 Answers
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Posted on Feb 25, 2009
  • Whirlpool Master
  • 19,396 Answers
The banging is usually due to a bad drum bearing, this also cause drum spinning in an irregular waw, and can be the cause for the gasket problem and the clothes not washing.
Replacing the bearing is not an easy repair and should be done by a technician.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Feb 13, 2012 | Whirlpool GHW9150 Duet Washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
Apr 17, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet washer make a loud banging sound during spin - louder when it goes into super spin
It sounds like the spider or support arms that hold the wash drum have failed and the drum is hitting the wash tub when it is spinning. Try spinning the inner drum by hand and listen for any thumping sounds as it turns. Also examine how it turns, if you notice that is wobbles as it turns, it also means that the supports are failing.
It can be fixed but it might be expensive. Get a few estimates before deciding to repair or replace. Hope this helps you.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
My Whirlpool Duet washer makes a very loud banging/knocking sound during the final spin cycle.
it sounds like you need a new inner tub,the three cross member sound like there broken
Mar 30, 2010 | Washing Machines
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
664 people viewed this question
Dan Webster
Dan Webster
Sal De
