Question about SanDisk Sansa e260 MP3 Player
Can't hear music from sansa
When I listen to my SanDisk 4GB Sansa e260 I can't hear any music come out unless i move the plug in, in different directions. It also only works in one ear.
    Scholar:
  • 47 Answers
Hi. If you have to adjust your earphone (even if you used other earphones) just to get a normal stereo sound, then the problem is with the player's earphone jacks. If that's the case (and assuming the radio feature of the player also manifests the same problem), then you may need to call the tech support guys at SanDisk for advanced troubleshooting, or possibly replacing that player. I found their tech support contact number at their website upon consulting prior issues I had with my player. Here it is: 1-866-726-3475.
Posted on May 16, 2007
SOURCE:
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
How do I get music onto the MicroSD?
Jan 21, 2010 | SanDisk Sansa e260 MP3 Player
How do i update my SANSA e260 4GB, firmware??
1. Download the SANSA Updater from:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
Sep 24, 2009 | SanDisk Sansa e260 MP3 Player
I have a sansa e260, 4gb capacity, that has a spot for micro sd mini chips. I recently puchased a 4gb mini sd ghip that is 4 gb and loaded it up with about 3.89 gb of music and the sansa will not detect...
The Sansa, in common with many devices which have been around for a while, will only recognize standard micro SD up to 2 GB, not the SDHC (High Capacity) variety.
Feb 18, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260 4GB Media Player manual
http://www.sandisk.com/sansa/#/support-0/
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 is broke.. HELP ME PLEASE!!!!
you have 2 things to do : 1- if you have the warranty you could exchane it. 2- Go to an lectronic store and buy the screen seperately, take the first one off than put the other one.
Mar 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
For everyone having e260 problems here is the answer. First make sure that you have your usb mode on msc before plugging in to the computer. Then go to folder options and select show hidden folders. You now have access to the music folders and can delete music. You can create a new folder or use the music folder for your music. To prevent future problems go to properties on the hidden folders and unhide them.
Jan 16, 2008 | SanDisk Sansa e260 MP3 Player
Can't add playlists
go to computer than click on Sansa e260
- Click on PPI NAND
- Click on PLAYLISTS
- Create a new FOLDER
- Give your playlist a name
- than put the music in it.
Nov 29, 2007 | SanDisk Sansa e260 MP3 Player
Sansa USB and Charger Problem
hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Aug 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
99 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
