Question about LeadSinger LS-3000 Consumer Microphone
Ac adaptor hi we have lost our ac adaptor for our lead singer karaoke can anyone help us to get a replacement
I actually was able to go to leadsinger's website: karaokesolution.com they had a replacement adapter for sale it was $9.95 plus a few bucks shipping which I thought was a GREAT DEAL! ***BUT****when it arrived, it was white, and DID NOT WORK WITH MY LS-3700. I eventually bought another system on ebay both LS-3700 mics worked with the black originally included adapter, and neither worked with the white one I purchased. The black one is an 8V and the white one a 9V so I think that is the problem. They both had the same polarity and mA limits. I tried a universal adapter but it had 7.5V or 10V to choose between and neither setting worked....I found an 8.5V adapter at a thrift store and gave it a try (((if you do this you MUST MAKE SURE THE POLARITY IS CORRECT OR YOU WILL FRY YOUR DEVICE AS SOON AS IT IS PLUGGED IN--it will smell like burning wires*)))
The Polarity is looks like this: [-] C-- [+] {a negative symbol circled a half circle around a dot opening faces the positive symbol circled and there is a line from the half circle to the positive symbol} Picture a dot in the middle of the C.
MAIN SOLLUTIONS:
1. GO ON EBAY FIND SEARCH "LEADSINGER MIC" and hope for a cheap replacement
OR
2. Find an AC adapter that is 8V-8.5V that fits and has a POSITIVE POLARITY -- Circle open to the positive symbol with a line to it.
Posted on Nov 21, 2012
It will fit any number of adapters. It is a standard size. The adaptor for my Netgeat router fit ours.
Posted on Jan 17, 2009
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
My karaoke machine won't work with the adaptor
Try changing your adaptor. The wires in a lot of the cheaper adaptors are small, and often break after too much flexing. You can buy a universal power adaptor quite cheaply, just make sure you set the polarity correct.
If that doesn't fix your problem, there may be an issue with the adaptor socket or the PCB board it mounts to. This will require disassembly to find the issue.
Nov 07, 2013 | Emerson SD512AC Karaoke System
I need a singer sewing machine 7105 manual
i am also looking for manual for singer 7105.
if anyone has it, please send it to : olkawka@o2.pl
thx
Jan 19, 2012 | Singer Sewing Machines
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
AC Adaptor lost
Will any power adaptor 12 volt DC charge a Vec013
Thanks
Apr 07, 2010 | JUMP START SYSTEM
I have lost the ac adaptor for my Hitachi Cam DZ-MV730A
I may be able to help you - I have an extra adaptor (for charging the battery) but not the AC cord or camera connection. Is this what you need?
Dec 17, 2008 | Hitachi DZ-MV730A DVD Camcorder
No power to the AC Adaptor
Thank you for getting back to me, however I contacted Miscrosoft and explained the situation and they are sending me a replacement.
Nov 24, 2008 | Microsoft Xbox 360 Console
How do i set my pc to connect to tv for karaoke i have nvidia
you need a male to male VGA lead to connect your laptop to a tv, make sure that the tv supports pc first, if not most DVD players supports karaoke
hope this helps
regards
Nov 18, 2008 | Computers & Internet
Philips Gogear HDD6330 AC adaptor / Sync cable
I know its not the answer that you really want, but these power supply/usb units do come up for sale on ebay quit often.
Sep 10, 2007 | Philips GoGear HDD060 MP3 Player
LeadSinger LS-3000 Consumer Microphone Logo
611 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
