Question about Canon IXUS 960 IS Digital Camera
Need to repair wrist strap attachment on ixus 960
The attachment to which the wrist strap fastens has broken. It appears to have been screwed on from inside the camera body and the screw seems to have come loose. I can hear something rattle inside. Is it possible to remove the front section of the body in order to get at this and fix it? Which body screws should I use? The camera still works. If I don't get to the screw is it likely to cause a problem?
    Genius:
  • 1,689 Answers
First things first, the small piece that holds the strap, when broken is repairable, but it is best that you dont since there is a strong possibility that the line will give up. the best options you may have to look for are camera pouches that are designed for the camera.
http://farm1.static.flickr.com/186/452068540_bf62b87687.jpg?v=0
http://ecx.images-amazon.com/images/I/51KXXHF3Q0L._SL500_AA280_.jpg
http://farm3.static.flickr.com/2117/2324527140_d133db348b.jpg
Posted on Jan 02, 2009
How do I latch my fitbit
Can't get my flex strap fastened. - Fitbit Community
https://community.fitbit.com/t5/Flex/Can-t-get-my-flex-strap-fastened/td.../194515
  1. Cached
  2. Similar
Mar 3, 2014 - I have trouble fastening my Flex, too. Not only is it difficult to line up the holes with the latch, but I somehow can't press hard enough to click the ...
Clasping and switching your Alta wristband - Fitbit Community
https://community.fitbit.com/t5/Alta/Clasping-and-switching-your-Alta.../1239815
  1. Cached
03-14-2016 13:19 - last edited on 04-25-2016 16:54 by ErickFitbit Moderator. Options. Mark as ... How do I clasp my Alta wristband more easily? Before putting ...
Solved: can't fasten band to wrist - Fitbit Community
https://community.fitbit.com/t5/Flex/can-t-fasten-band-to-wrist/td-p/536044
  1. Cached
  2. Similar
Since it wasn't on my wrist, I could see how to align the band to get the clasp to go through both pieces of ... HelenaFitbit ...... I cannot get my fit and to latch at all.
How can I latch the band easily? - Fitbit Community
https://community.fitbit.com/t5/Flex/How-can-I-latch-the-band-easily/td.../98355
  1. Cached
Jan 19, 2014 - Latch is very difficult. Accepted Solution. 0 Votes. Reply · All forum topics · Previous Topic · Next Topic. 1 REPLY. 01-19-2014 20:16. Options.
Anne Corey - I can't attach my Flex to my wrist. Can not... ' Facebook
https://www.facebook.com/fitbit/posts/595334813824040
  1. Cached
  2. Similar
I can't attach my Flex to my wrist. Can not get the little teeth to go ... To see more from Fitbit on Facebook, log in or create an account. Sign UpLog In. Not Now. How do latch my fitbit Google Search
Dec 28, 2016 | Exercise & Fitness
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
Leather watch bands are broken
The "gizmo" would be the pin that attaches the watch to the case. You can easily purchase a replacement pin or strap at any store that has watches (even Wal-Mart). These are very inexpensive and each one will cost you less than $10.
Jan 03, 2009 | Fossil AM3695 Wrist Watch
Mode Switch Broken
It's a fairly easy repair, but you'll need a scrap A2 to cannibalise for parts. They're fairly easy to come by and cheap on auction websites as so many A2's have broken.
What you need is the complete LCD top-plate assembly as trying to refasten the mode switch is a waste of time if the spindle is broken..
To remove it from the donor camera, remove the neck strap from the camera handgrip. Now open the battery cover and undo the screw at the far end of the battery chamber: you'll need a long precision cross-head screwdriver to do this and preferably a magnetic one to withdraw the screw and subsequently replace it. Next, look at the back of the camera, just above and to the left of the power button is another screw; remove it.
Now earth yourself with an earthing wrist strap available from any electronics store and most computer components stores as you're going to be in contact with microelectronics and you don't want to fry them with static discharge.
The panel should now lift: as you do so there are two flexible printed circuit boards to detach and one small plug. Using a pair of tweezers, or the blade of a flat precision screwdriver, ease the plug out, DO NOT just pull on the wire. The two flexible pcb's can be gently pulled from their holders, but a better way to do so is to release the clamps holding them in: the narrow, rearmost one uses a clamp which slides rearwards and the wider frontmost pcb uses a clamp which hinges upwards. The first type of clamp is black (in contrast to the white socket) and using a flat tipped 1mm screwdriver at the edges of it you can easily pop it backwards, the other one is normally blue, but can be yellow and simply flips upwards to release.
You can now completely lift off the panel complete with the mode switch.
Now do the same with your broken camera; it's much easier now that you know what to expect!
Refitting is in reverse order, take care that you don't bend the flexible pcb's any further than you need to when refitting them and be careful to reclamp them by pushing the hinged clamp downwards and sliding the other clamp in until it clicks on both sides. The miniature plug can be a bit fiddly and it's designed to only go in the right way up. refit the screw adjacent to the power button. The most awkward bit is refitting the tiny screw inside the battery chamber so just be patient with it and persevere, and don't fit it until you've checked that the camera is working correctly.
If you've done everything correctly then pat yourself on the back. If anything is not working then you've not fastened one of the pcb's or the plug correctly and will need to do the job again.
Dec 30, 2008 | Konica Minolta DiMAGE A2 Digital Camera
Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Dec 19, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Battery lid or cover
I have a s5500 with the battery lid clips broken.. fuji says ,, nope no warranty on that part ,, what a joke,,$120 dollars labour plus parts and freight for repair... anyway ,, went to jaycar (electrical supplies etc) and found a small metal clip/ fastener that I used on an existing exterior screw below where the strap is located. i then placed another screw in the lid that allows the remainding hole in the fastener to slip over, works like a charm. took me around 3 minutes to do and does not affect the grip on the camera and still alllows it to be easily opened and closed. I am most pleased i now have my camera back.
Feb 10, 2008 | Fuji FinePix S5100 Digital Camera
Wrist strap for LG vx5200
sorry there is no way you can get a covering with a wrist strap
Oct 08, 2007 | LG VX5200 Cellular Phone
Canon IXUS 960 IS Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
