Question about Dell Inspiron 1501 Notebook
Dell inspiron 600 got wet and won't turn on
My four year old wireless dell inspiron 600m laptop sat in some spilt water all night and won't turn on...the power cord/chargers light is green but when plugged into back of laptop the green light goes out and system is dead...laptop won't turn on with the battery in either...no lights on the back of the battery lit to tell me if it's charged....borrowed someone else's charger and power cord and same thing happened....green light on but when plugged into the back of laptop the light goes out...it's been two weeks and should have had time to dry out...no water now seen anywhere...what do you think is wrong and how much to fix it?--i don't want to spend alot of money on it
  • 1 more comment
  • slsjcs Jan 02, 2009
    yes...i tried it with the battery out and just the charger--nothing...it has something to do with the charger/power cord being plugged into the back because the green light goes out...anyone have any ideas?...what is the fix to a "short" problem?
    i just don't know......
    yes...i would like to inspect the internals and recover the files....if you have links to how to do it ....it would be helpful....thanks....do you think if i buy and install a new motherboard that will fix the problem....s
  • 368 Answers
Sitting in water all night would have given it a lot of time to penetrate, and if there was any power to the unit during that time, it could have caused short-circuits (either from battery or line-voltage) that could have zapped the logicboard or other static-sensitive parts.
If you want to tinker with it, I'd recommend getting parts off eBay (screenshot from current Inspiron 600 motherboard auction to follow below), and trying to rebuild it. Given the cost of a new Dell laptop starting @$500 (from www.dell.com), you might easily spend more money on parts (and please consider - - what is your time worth?) than on buying a new unit.
Perhaps more important - is your hard-drive recoverable? When was your last back-up? If you need to recover the data, you'll need to either plug it in to another computer to recover, or find someone (this usually means pay a professional) to recover it for you.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 02, 2009
    Genius:
  • 1,269 Answers
That's short circuit problem. What you can do is disassemble all the parts and use a blower to dry all areas. Dry it under the sun as well. If you can unplug and replug the memory and the CPU, please do, and dry it as well using the dryer or blower. Replace the BIOS battery as well because that might be the problem.
    Scholar:
  • 111 Answers
Hi sorry to hear about your laptop I can relate to similar experiences, since the laptop sat in some water for so many hours, you would have to figure some water would have to gotten into the are of the logic board, since there really was no way for you to dry it out immediately the chances are good that the board got damaged. After two weeks drying time you would not find any water anywhere. So it's a safe bet that whatever water caused the damage is long gone. The cost to replace a logic board on ao Inspiron 600 that is out of warranty is equal to or greater then cost of the laptop, unless you can replace it yourself and save the couple hundred dollars labor, it's just not worth fixing. There really is no good news when something like this happens unfortunately water and electronics don't mix.
Sorry to be the bearer of bad news.
Ken
  • 3,037 Answers
Hello slsjcs
Sounds like you may have fried the motherboard. You need to unscrew the screws out of the bottom of the laptop and confirm this. As it could be anything, you need to test all components. If your friend has the same laptop, you can remove them one by one and try them in their laptop until you find the one that is faulty otherwise you may as well pay for a tech to look at it and narrow it down as I can't tell you for sure as anything could have been damaged (multiple parts could need replacing). It may be time for a new laptop as it probably won't be worth it to fix this one unless it is covered under any warranty by dell still.
bestdarngood
  • Dell Master
  • 13,433 Answers
The motherboard may have got wet. or there maybe water still inside.
debends on the damage I would look inside and see how it is.
worst case scenario you have to replace the motherboard, its the highest price part in the laptop, debends... from anywhere 200 to 1000
  • 1 more comment
  • Ekse Jan 02, 2009
    Is there anything I can do to help? are you planing to inspect the internals of the laptop or?
  • Ekse Jan 02, 2009
    if you need instructions in recovering your files or anything else drop me a comment on this page and I will get back to you when I'm available.
    Thanks,
    Ekse
  • Ekse Jan 02, 2009
    without a closer inspection I can't say for sure, but very likely yes it would fix the problem.
    but consider the price of a new laptop agains the price of a new motherboard.
    www.pchub.com for example sells laptop parts
    you can also look around www.ebay.com for a cheap deal, but unlikely to find the exact match.
    A service manual with take apart and put back together
    instructions is available at
    http://support.dell.com/support/edocs/sy...
    tm
    All your files should be OK, you will need to remove the Hard
    drive from the laptop, possibly purchase a 2.5" to Ide Connector
    adapter, I haven't looked on the specs so its either a small ide
    connection which requires a adapter to be plugged into a desktop
    pc or sata which connects directly into a free sata connector on
    your motherboard, assuming your desktop motherboard has SATA.
    You could possibly consider a USB CASE for the hard drive you
    would be able to use the disc as a usb drive, easyly useable on
    any computer with a usb port. a usb 2.5" hdd cases are cheap.
    For example a ide hard drive will fit into this case
    http://www.amazon.com/USB-External-Enclo...
    FNBYKW
    and here is a similar case for SATA hdd 2.5"
    http://www.amazon.com/SATA-Hard-Drive-Ca...
    08
    How to tell which one you have ones you have the Hard drive out
    from the pc? SATA has two flat connectors, a wider one for power
    and a smaller one for data.
    IDE has around 40 small pins sticking out of the hard drive.
    Note that your hard drive when you remove it from the laptop
    maybe stored on a case already it may have a diffrent connector,
    remove the cover and the connector adapter if any from the hard
    drive and you will get to the proper connecotrs.
    heres a picture of a 2.5" laptop hard drive removed from the
    laptop and any extra caseing has been removed, its ready to be
    installed to a desktop computer with a adapter or to a usb case
    directly. in the picture we have a IDE disc
    http://www.laptoprepair101.com/wp-images...
    Brigadier General:
  • 5,158 Answers
Try it without the battery in and just the charger. it does sound like something has shorted out
    Genius:
  • 1,142 Answers
Call up dell and tell then that u are getting electric shock they will replace the the system, trust me. they will and dont tell that you have spilled water, they will replace the system
  • Maanita Chadha
    Maanita Chadha Jan 02, 2009
    number is 800-6249896
  • Maanita Chadha
    weather its in warranty or out off they will replace it in shock hazard policy
  • Dell Master
  • 19,396 Answers
Whenb this happens, a laptop must be taken apart completely and dried over using a hairdryer on cold.
Better having the job done at a repair shop.
  • Ginko
    Ginko Jan 02, 2009
    You can leave it even one month, if the water had penetrated inside, it may stay trapped and wont evapourate, but it will keep condensing inside the unit.
    Additionally, the decision to leave the computer in this state for over one week may have caused formation of oxide, and therefore further damage.
    If the laptop was connected to charger, or wiht battery mounted inside when the accident occured, you may also have additional damage (eg. damaged motherboard) due to short caused by liquid damage.
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
I cannot log onto my facebook account with my 6 year old Inspiron 600M, but okay with HP laptop
Your 6 year old most likely has an obsolete system. It may not understand the new codes on some web pages because it would need updated Java and browser version. Java is meant to have automatic updates, but if yours doesn't do that then go to java.com to get this going. The new browser version should be IE8 currently. But if you use Firefox or Chrome or any other application, then see if you can get updates on those. If my ideas help you, please do rate me. Thanks
Feb 05, 2010 | Dell Inspiron 600m 1.6GHz Pentium M...
Dell insprion laptop contains wlan card or not?
Well I think for the 600m, it has built-in wireless already thus making it wireless capable.
Aug 15, 2009 | Dell Inspiron 600m Motherboard C5832
Spilled water on Dell Inspiron 600m
When you experience this problem it's usually one of these four hardware components.
inverter
video card
backlight
video cable
The only thing you can do is replace each item until you find the one that is causing the dimness.
I'd recommend getting it repaired through a local repair shop. Stay away from the Geek Squad.
Or you can go the d.i.y. route and buy the inverter from ebay for about $10-15. Problem is you'll have to install it, it's not hard but you'll have to put aside about 20-30 minutes to do it.
Hopefully this info helps. Let me know if you have any other questions.
Best of luck!
Feb 26, 2009 | Dell Inspiron 1501 Notebook
Insprion 600m Reddish Tint when on Battery Power
hi there,
you are probably not getting enough power source from the battery or the battery is getting old and not charging fully or holding its charge ,is my guess good luck..try a new battery...
Jan 22, 2009 | Dell Inspiron 600M Notebook
My hard drive took a **** and my dvd burner will not pop out
Hi a_stoeger, it is possible for you to get what you need. Or even better. Below is a list of links for your viewing. The best site is the first link.
Hard disk drives for the Inspiron 600M laptop. (Great site).
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=dll&pos=0&type=itemid&itemid=dll9
CMS Products Easy-Plug Easy-Go Hard Drive - 60GB - 4200rpm – Ultra
This hard drive is designed for Dell Inspiron 500, 600m Series.
http://www.google.com/products?q=60GB+Ultra+ATA+Hard+Drive+for+Inspiron+600M+notebook&btnG=Search+Products&hl=en&show=dd
Brand New CD-RW/DVD Combo DRIVE for Dell INSPIRON: 300M,500M,510M,600M.
http://www.acer-laptop-battery.com/cdrwdvd-combo-drive-dell-precision-m20m60m70-p-466.html?zenid=12m5dirv47ffvjf6jc5pc85lp0
New combo drive. Fits the 600M
http://www.upgrademaster.com/dvdrw-cdrw-drives-c628/dell-dvdrw-cdrw-combo-drive-p26078.html
Brand New CD-RW/DVD Combo DRIVE for 600M 500M With One year Warranty
http://www.power2battery.com/dell-inspiron-600m-500m-cdrwdvd-combo-drive-p-697.html
If there is any life left in your notebook drive connecting it to another IDE drive could allow you to transfer the data to the PC.
This next link is for connecting your laptop drive to a PC drive.
http://www.paddlersite.com/2lato3deideh.html
Cost effective!
Good luck a_stoeger!
Mike
Jan 05, 2009 | Dell (04U621) for Latitude D600, Inspiron...
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Computer wont turn on
How long ago did this happen?
Remove the power adapter and the battery.
Remove any removable covers from the bottom of the laptop and look for any signs of liquid. Leave the covers off for a couple of days to allow any liquid or moisture to dry up.
Press and hold in the power button for up to 60 seconds to discharge the laptop.
When you are sure there is no more moisture present try starting the laptop.
If it still won't turn on something may have shorted out during the spill and you will probably have to take it to a repair shop.
May 05, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Dell Inspiron 1501 Notebook Logo
64 people viewed this question
Alun Cox
