Question about Dell Dimension 2400 PC Desktop
Will not recognize dvd rom
It's a dell dimension l700cx. i removed thcd rom because it only has one slot an installed a pioneer pidvd-115lh dvd rom. no matter how i jumper it nothing shows up. it will open an close tray but the system windows 2000 does'nt show it's there. no icon in my computer
  • gholt35 Jan 02, 2009
    it's not shown in hardware. no driverdisk.
Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
What are your computers specs?
Posted on Jan 02, 2009
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Can't get Dell Desktop to recognize cd/dvd on D: drive
With any computer this is a question that must be answered by those that provide the driver software. Like the number above (Dimension 3100) you should begin your search here=> Dimension 3100 Drivers that is if you have not altered the driver by putting a different player in the slot. What you need to do is test the drive using the Dell diagnostics. The procedure can be found in the CD/DVD FAQ. Run the "read test". You'll need to insert various disc types during the test. This came from Dell Forums. Click Here=> Dell Forums/Osprey and Here=> Search Results for "Dimension 3100 DVD Driver"
Hope this helps, Thanks, Sea Breeze
Jul 14, 2010 | Dell Dimension 3100 PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
Just installed new HP dvd1270i. PC boots but
Check your power connector to the DVD Rom and also check the cables (Sata or IDE). If this doesn't bring any solution, scan your system using updated anti virus. Good luck.
Apr 07, 2010 | Dell DVD-ROM for Dimension (6t903)...
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Configuring dell optiplex 755 sff
on the back of each device their should be a jumper on the right side next to where the ribbon cable plugs in. Remove the jumpers and replace them into the slot thats for "Cable Select" Their should be a picture on the top of the device if they aren't labeled. You can also put the jumper for 1 as "Master" and the other as "Slave"
Apr 20, 2009 | Dell 16X DVD±RW Serial ATA Internal Drive...
CD rom
hi
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
ok
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2400 PC Desktop Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
