Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
Chris Sliman Posted on Jun 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to realign the picture tubes
When you turn on the tv you get a blue outline of the picture to the right of it. I tried the convergence but that didn't work. The model # of my Samsung is pck6115r. It's a hdtv ready rear projection and was made in 2000.What I need to know is how to realign the picture tubes once I take the back cover of. Any help you can be would be greatly appreciated. Thanks, csliman
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 06, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1416
Points
Premtech's solution #1,is very good advice. I would also change the STK...IC's and the value of the resistors feeding the amps. I also agree that perhaps it is best to take the set to a qualified tech.
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Jun 01, 2007
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504594
Points
2229
You should NOT need to re-align the crts to correct this problem... Chances are the failure is in your convergence circuit and most likely the convergence amps, (IZ103 & IZ104)Samsung p/n#AA62-30173D which may be substituted to an original STK394-250 and you'll need two of those. (Make sure they're not cheap knock-offs).. You may also want to test the resistors feeding those amps for change in value. And if I've lost you with any of this take the set to a qualified tech for the reapir - - you'll be money ahead... Under no circumstances should you need to change or alter the CRT placement. Chances are better for you winning the lotto three times in a row than it being a placement problem...
2answers
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
40wh08b convergence problem
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ 01341...no cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
2answers
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
How can I get rid of the red and blue outline on my tv?
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2answers
KP-57HW40 Sony ..picture is blurry and gives me a headache also has a blue green tint and redish outline of the people???
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
1helpful
2answers
Picture in out of alignment when hdmi on looks like a 3d movi
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
1helpful
3answers
My hitachi 60SBX72B having picture convergence problem, how to fi
Your TV most likely has one or more possible problems.
  • Screen looks 3D
2answers
2001 Philips 43P8341Blue outlines on images
  • Screen looks 3D
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
