Question about Intel Motherboard
SolutionCenter.msi hi, whenever i open my cpu, a dialog box appears "The installation package for solution center cannot be found. Try installatio again by using valid "SolutionCenter.msi". i am a registered acer user and hope you could help me out in this...thanks in advance..
  • Anonymous Jan 11, 2009
    please help
  • Anonymous Apr 30, 2009
    I don't have the solution but I know the cause of this issue. It seems HP in their infinite wisdom, hardcodes the version of Flash that Solution Center uses into the installation file. Once you go past that version, Solution Center no longer works. HP makes it so you have to keep using old, unsecure flash player software in order to keep using solution center. nice
    Problem Solver:
  • 6 Answers
Not much info given here, but try unloading the process at startup by Clicking the "Start" button, select "Run", type "msconfig" without the quotes, and hit Enter. On the "Startup" tab select and remove the check mark next to the startup item that is associated with the solution center. This item may be obvious or you may need to plug a few of executable names into a Google search to find the culprit. OK the removal and restart the computer. Depending on the operating system you will be prompted not to show a notice about changes made. Not to worry, in almost all cases the procedure can be reversed if by chance the wrong item is removed. PC-Professor, good luck!
Posted on Jan 16, 2009
Hp 5590 "solution center.msi" error, cancel,cancel,cancel??? 5590 is looking for ; "solution center.msi" ??? not on original CD, maybe HP has a download for this MSI?
You can locate the Solution Center.msi under the printer software CD
the path is CD\Setup\Solutioncenter\solutioncenter.msi
When it ask you to locate the msi file and if you are not able to locate it from CD, my suggestion would be to uninstall the software as it may be outdated and download the latest software and install it
To download the latest software for your scanner click on the this link - Download
Choose the operating system of your PC and under DRIVERS section, download the FULL FEATURE SOFTWARE
Oct 20, 2010 | HP Scanjet 5590 Flatbed Scanner
HP Digital Media Archive Pop UP
its been how long that u ahve been facing this problem
Apr 06, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Pop up solutioncenter.msi. Fix this problem?
Copy and paste this address into your browser, download and install the Windows install cleanup tool. Open it up after installation and look for anything labled solution center and remove it. Be very careful not to remove anything else, restart your computer and the issue should be resolved, at least it worked for me.
http://support.microsoft.com/kb/290301
Nov 26, 2009 | HP Pavilion dv9000z Notebook
Reinstall Sonic MyDVD from the Application Recovery. A lot of HP computers have done this or produced that constant pop up.
If that doesn't work, go to:
Start > Run and type in msconfig in the box.
Then click the Startup tab and uncheck the box beside DMA (digital media archive)
Click Apply then Close. Reboot when prompted and you shouldn't get that annoying pop up any longer.
If you don't even use the Sonic MyDvD program on the computer, just uninstall Sonic completely from Add/Remove.
Mar 09, 2009 | HP Pavilion Media Center TV m7680n PC PC...
HP Solution Center -- New Computer
I removed all the software for HP scanjet 4890 from my pc en and afterwards installed new software (from the internetsite of HP). Then the problem was solved
Mar 02, 2009 | HP Scanjet 4890 Photo Scanner
HP Solution center doesn't start...
I'll assume that you actually have an HP printer (or scanner) attached to this unit.
Uninstall the HP drivers and software which came with your HP printer (or HP scanner) and reinstall it from the driver discs (reinstalling the HP software over the existing installation may take care of it also). If you don't have the discs that came with your HP equipment please post what model you have and I will track down a link for you to download the necessary stuff for reinstall.
Feb 26, 2009 | Acer Aspire 5315 Notebook
me aparece una ventana dificil de serrar pidiendome el archivo ezarc.msi
Aug 25, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Sounds like you have may have it run on startup. Just to see you can use msconfig to temporarily disable it by following these steps:
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information.
Thanks
Aug 08, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Help... 1640n
Here's what HP has to say about your error...It appears to be an issue with Sonic MyDVD. Reinstallation of the program seems to be the solution.
Jul 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
well guyz... i got a solution... while u get the pop-up... open the task manager... and then search for the process DMASCHEDULAR
and end the process... it worked for me...
Feb 09, 2007 | HP Pavilion a1410n (ER890AA) PC Desktop
Intel Motherboard Logo
2,265 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
