Question about Fiskars Brands Computers & Internet
I have a 1988 Fiskars UPS 1.5 and I need the service manual.
I am pretty sure the battery's are bad but I want to install an external battery and just use it as a remote power supply without charging the battery with the device. I have a source of 12 or 24vdc power and just need clean 120Vac to use with other devices. I don't have much of a budget and we are in need of a cheap power source.
Thanks
Ron
  • 7 Answers
SOURCE: 3000 VA UPS Service Manaul of Fiskars Power Systems Make
I have the same PCB on my Deltec PRR2200i. I at least know a few things about the circuit now. I had 11 transistors explode on mine and am replacing them now. Sadly I have not managed to track down a circuit diagram.
Posted on Mar 30, 2010
What if I don't replace the battery? What happens?
Have you ever let AA batteries sit inside of your tv remote control and forget about changing them... then find out that you really need that remote but when you go to replace the batteries you find a mess because the batteries were wayyyyy past their life cycle?? That's pretty much the same thing that's going to happen except on a bigger scale. I can't answer this question and say that nothing bad will happen (sometimes a bad battery with a lot of current provided to it will get so hot that it will explode!) but more than likely -- no. These units are designed as an offline UPS (you can read more here: http://psihq.com/products/ups-systems/) so there will not be steady current going through the battery all of the time.
My sincere advice - if you're done with the UPS then unplug it from the wall and recycle the battery; then you can store your UPS for later use. Remember, it's against the law to throw batteries away, you must recycle them! Well... in the States anyway.
If you would like pricing on a new UPS, we can offer pricing better than any big box store (walmart, bestbuy, etc...). Contact me whenever & in whichever way is easiest for you:
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 07, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
I have a Siemens Masterguard UPS A3000 model. I gives out an audible alarm (bleep) once every minute. The unit has had new batteries installed but the problem persists.
Are you sure the batteries installed are new? Sounds like a low battery alarm.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Aug 28, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
Does not power on
Please check whether you are getting any power on the UPS or not. In case it is not working even on the AC power, then it might be the transformer inside the UPS which has burned. It can be easily repaired by taking it to any APC service center. This does not seem to be an issue with the battery since the UPS is not even turning on
Apr 29, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
No Output from UPS ACP BE650R backup
I too facing the same problem ?
If supply is switched off UPS also shutting down.
But the battery is fine. Back up is not comming.
Any body help me in this regard.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Need instructions to install a new battery
1. If you have a dell computer, visit www.support.dell.com. 2. Enter services tag and click on manual.
or if you have any other computer, please visit the manufacture's website, and in the search box, type in, Manual.
Feb 10, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
No backup shut down in 30 seconds
The battery is either discharged...or bad...charge it for a day..if thats doesnt fix it...then you need to purchase a new battery
May 31, 2009 | Fiskars Brands Power Sentry 100896 UPS...
To increase backup in apc symmentra ups
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | APC Symmetra Tune-UPS technical support -...
Ups taking no load and gets of within 30 seconds
I thought Fiskars quit making UPS, after powerware bought them out ages ago.
Two hours...you need a much bigger UPS to get two hours of run time. A 2200VA depending on t he load is a challenge to run two hours. Something like that would cost $400.00
30 seconds sounds like an over load issue.
Aug 08, 2008 | Fiskars Brands Power Sentry 100896 UPS...
Jul 20, 2008 | Fiskars Brands Power Sentry 100897 UPS...
Computers & Internet Logo
213 people viewed this question
Top Fiskars Brands Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Fiskars Brands Computer and Internet Expert? Answer questions, earn points and help others
