Question about Philips Magnavox DVD/VCR Dual Player
Connecting to cable tv
We recently bought a Magnavox DVD/VCR for a parent. Her tv is about 2 yrs old (also a Magnavox) and only has the yellow & white jacks. How do we hook up the unit to the tv.
I have Time Warner Cable, want to utilize just one remote control for access to the Magnavox TV and VCR/DVD player?
All connections are from what I can see correct?
Posted on Jan 04, 2009
  • 3 Answers
If you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Posted on Jan 02, 2009
Cant hook up magnavox dvd player to t.v.
i hope the dvd player has the RCA cables for connecting the input signals to the tv for display and sound. the cables have input jacks at its ends and the same are color coded for easy identification on where to plug it in. with the use of colour insert the yellow pin to the tv yellow input and the same to the dvd and do the same to the white and red terminal and proceed on by turning the channel to AV and play
Sep 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Hello. I recently bought a magnavox dvd/ vcr and attempting to connect it to my Sanyo DP32649-06 TV. The magnavox does not have the ant in or ant out plugs needed for my cable to appear on the...
Can you tell me the model # of the Magnavox?
What type of "out" connections does your Magnavox DVD have?
Old style Coaxial RG6?
Composite (Red and White for audio \ Yellow for Video)
Component (Red and White for audio \ Blue, Red, Green For video)
SVideo
HDMI?
Jun 11, 2011 | Sanyo Televison & Video
I just bought a digital video disc player & video cassette recorder. I'm having a problem connecting the player to my TV. My model No.is DVP3345VB/F7. Where I'm having a problem is the cable source...
You now connect the cable and the combo directly to the tv by using different connections: the cable goes in the antenna entry and the combo is connected to the tv with a 3-headed RCA cable - with heads of Yellow, Red and White.
Then when you want to see one or the other you just select the appropriate source from the tv's menu using the Source/square with arrow in it/AV or whatever is called in your model button on the remote.
Nov 04, 2010 | Philips Magnavox DVD/VCR Dual Player
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
Jan 13, 2010 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting dtv box to vcr to dvd to the tv
you can hook the cable box into the vcr and then out of the vcr into the spliter which will turn your tv red/white/yellow signel input into two inputs( you can get this at most radio shacks for about $7.00 dollors) this leaves you with one more input for the dvd player
Please rate my response and come back if you need more help!
THANK YOU!
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
Magnavox DV220MW won't record.
You need to plug a red, white, and yellow cord from the red, white, and yellow OUT of your cable or satellite box into the red, white, and yellow labelled VCR IN/LINE 1 on the Philips. To view what you are trying to record, make sure there is another red, white, and yellow cable plugged from the DVD/VCR OUT of the Philips to your television. Make sure the television is on the appropriate source channel (AUX 1, AUX 2, VIDEO 1, VIDEO 2, etc). Then press the VCR button on the Philips. You should now see your cable or sat channel (as long as it's not an HD Satellite box) on the television screen. Press record, and you are on your way. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Philips Magnavox DVD/VCR Dual Player Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
