Question about Lasko 2115 Wind Tower Fan
How to open the casing
How do you open the shell of a Lasko Fan 2115? I'd like to clear the blade inside and perhaps, I might also see why it's a bit wobbly towards the base.
  • 26 Answers
Question does the base underside have any removable screws that you can remove? If so, start from there. The top part of the fan should pop off with a screw driver. Exposing the screws securing the shell of the fan.
Posted on Jun 21, 2007
How do I take off to replace a lasko cyclone 3542 fan blade ?
Bex,
THose usually just pull off. You will have to pull hard because there is a spring clamp that they sometimes put around the inside hub of the fan. If there is a clamp, you will need to transfer that to the new blade. Hope this helps!
Jun 13, 2015 | Lasko Dryers
How do i take apart my lasko cyclone fan to clean the inside of it
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
Aug 09, 2014 | Lasko 3510 cyclon Floor / Box Fan
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
Is there a way to open fan to clean blades? ty
yes, there are screws on the side that you have to remove first. you have to remove the screws for the handle on the outside of the fan case, but the rest of the screws are on the inside of the fan case. you will have to move the fan so you can get to the screw that is hiding. you will want to take the side off that does not have the power switch on it. I also like to use an air compressor to blow the fan out as well. this works just as good.
Sep 06, 2011 | Lasko 4900 Portable Fan
Fan rattles when running. It appears that the fan blade hits the inner plastic piece behind the fan blade.
Open it up by removing screws and plastic backing. See this black round rubber fixture? Apply some WD-40 inside it and you'll be back to quiet fan operation.
Jan 15, 2011 | Lasko 3300 Wind Machine Fan
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
How do you take off the spinning part off of a lasko fan?
Just hold the blade and use a sharp knife and cut the string. It's really not that hard!
Jul 28, 2009 | Lasko 3300 Wind Machine¿ Floor / Box...
I want to take it apart to clean the fan blades ....how do I get to the blades.Cant figure out how to take off the protective grill?
remove all screws from the back and then slowly pry off from the back its click on there are latches that secures the backing, also remove the screws that holds the controls.
slowly pry open the case, i did mine in the middle and work my way around the unit, but it a bit tricky..
the best way to clean the device is to use a air compressor, strong air blowing inside while holding the blade with a screw driver. and even using a paint brush with long bristle, while blowing, this way you dont have to take the device apart.
good luck
Jun 28, 2008 | Lasko 2530 Elite WindTower Fan
Lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Apr 21, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko 2115 Wind Tower Fan Logo
368 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
