Question about Acer AL1716 F Monitor
Computer crashes My PC crashes without warning! Sometimes it drops out after 5 mins of use and sometimes it can be after say 2 hours of use, there is no pattern to it. I have trend micro anti virus software installed but it keeps on happening? Can anyone help.
    President:
  • 2,976 Answers
You could have a few different issues. You most likely have some sort of spyware and malware on your computer. Download some of the free cleaners available and clean things up a bit. You also probably have heat issues. Make sure your air vents are kept clean with a vacuum, not canned air. The canned air only blows the dirt into works. If you're using a laptop, canned air is probably the only option. Also, gat a cooling fan to put under the laptop. They work wonders but, you will have to keep those fan vents clean also.
Posted on Jan 02, 2009
MY Asus K70 AC won't start. Put in a new battery, no result. Startup Only with adapter, so without the accu. no result. Sometimes after many hours it starts and all functions go very well. It has
If it stays on long enough I would look at the error reports (you can google how to check that) and see if there are any critical errors that are affecting it from starting up or makes it crash and appear to not start up almost immediately after start-up.
If its a new computer there is a chance that there was a manufacturer flaw and 1) Could have been damaged during transportation, 2) Could be a design flaw if it was customized, 3) Could have been damaged while being built if customized, 4) Dropping it the wrong way could make it so the battery can't interact with the PC
To clarify, when you say it starts up after many hours, is that while plugged in and does it say the battery is charged/charging or is it a hit and miss type of thing where it will sometimes start up and sometimes not?
I hope this helps, but if it doesn't you should try to provide a bit more information as to the issue!
Nov 23, 2014 | ASUS Computers & Internet
STALLING AND STARTING PROBLEMS
How do you know that the FUEL PUMP is working? you have one of 3 issues
a. Fuel Filter is Clogged
b. Fuel Pump is not providing enough pressure (40 PSI required)
c. Ignition Module is going bad.
My guess is Fuel Filter or Fuel Pump. Put a Gauge on it and read the pressure... You may find out that you have a pump making noise and not providing enough fuel pressure
Apr 05, 2013 | Cars & Trucks
.ukmy ps3 cuts off when
Hello there smithy
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Sep 06, 2011 | Sony Playstation 3 (PS3) Console
My computer reboots without warning at different intervals
this problem occurs if your computers cooling is not as its necessary to be.try useing it with an open cabinet and see if the problem persists. if the problem still persists remve ur CPU fan and place some heat sink fluid and place it back on the cpu. then all your problems should be gone.
use a good antivirus to check for any viruses before this(just in case)
Aug 10, 2009 | Computers & Internet
My computer crashes or freezes a lot
It might be a virus.
Probably Lsass virus. This virus can get into your computer and really cause havoc with your network connections and also deny you access to certain internet sites.
You need a Lsass removal tool.
try to go here http://www.symantec.com/security_response/writeup.jsp?docid=2004-050114-1706-99
and download the tool, and follow the instructions.
good luck
Mar 31, 2009 | HP Pavilion a450n PC Desktop
Crashing
If your problem has not been fixed
Repost your problem so that one of Fixya'a Experts can see it on the Unsolved Problems List.
Mar 29, 2009 | Palit Microsystems GeForce 9800 GX2, PCI...
The HDD speed suddenly droped
Check the pins connecting the HDD and Motherboard.
Aug 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
Acer AL1716 F Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
