Power Supply needed for Phillips 42PW99 6217
I have a Phillips 42" plasma TV manufacturered around 1999-2000. the Model # is 42PW99 6217. I am in need of the power supply/volume & channel control box. Can anyone help?
Email me at, I have the original box for this tv. My tv is not working correctly, but the box works fine! All the functions of the box work, although my tv is damaged. Make me an offer and the box is yours!
Posted on Jan 13, 2009
I Why won't my Phillips 42"plasma tv turn on?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 26, 2015 | Televison & Video
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
My Phillips Tv keeps turning itself off after around a minute,the power button remians on and green but no picture or sound. It is like the fuse keeps tripping. If you unplug the tv and switch it back on...
The main power supply is trying to fail. You might try giving us the model number since we can't guess exactly what kind of TV you have; LCD or plasma?? They suffer from some differing ills-
Oct 23, 2009 | Philips Televison & Video
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
I need help tv plasma phillips
Hello gruponapa,
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
I hope this helps,
Thank you,
Jul 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
