Question about Maytag Performa PAV2200
Water level will not stop at medium
Water will not stop at medium level shut water off and still fills
  • Maytag Master
  • 3,463 Answers
You have a sticking water level switch caused by a blockage in the hose or pressure chamber, or a sticking inlet valve..
If it is a valve, then water would keep on coming in even though the washer is off, if this is the case, then fit new valve..
If it is the level switch you will have to unblock the hose and and chamber.
Hope this helps.
Posted on Jan 02, 2009
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
Cold water does not stop at set levels. Too much flow.
Blockage in pressure bottle or small hole in pressure bottle tube.
Feb 25, 2010 | Washing Machines
Washing machine wont fill with water when switched on
Fillingwith water:
The waterfill valve - The water fill valve is a mechanical and electrical part,the coils on the valve need electricity to mechanically open the valve to allowthe water to flow into the washer....myth....the washer pumps water into itself...no, itdoes not. The fill valve opens and the house water pressure pushes the waterinto the washing machine.
No cold wateror no hot water - The fill valve has two coils, one for the hot water and onefor the cold water. It is possible that one of the coils can fail and you loosethat filling ability. If the cold water coil quits, the hot will still work andduring warm fill you will get hot water only and during a cold fill you willget no water at all. If the hot coils quits, you will still have cold waterfill, cold water only on a warm setting and no water on a hot fill setting. Youcan No cold water or no hot water- The fill valve has two coils, one for the hot water and one for the coldwater. It is possible that one of the coils can fail and you loose that fillingability. If the cold water coil quits, the hot will still work and during warmfill you will get hot water only and during a cold fill you will get no waterat all. If the hot coils quits, you will still have cold water fill, cold wateronly on a warm setting and no water on a hot fill setting. You can testa fill valve live for 120volts, power to a fill valve coil and no fill = a bad fill valve. You can also testthe coils for continuity, nocontinuity = a bad fill valve. Some Maytag washers have a fuse in the fillvalve circuit, if this fuse let go the washer will not fill. Fill valves canalso from time to time stick open and not stop filling. If you have to shut offthe fill valves to stop the water fromfilling in the washer, you have a bad fill valve and you will have to replaceit.
Water level controls - The water levelcontrol is also know as apressure switch, this is where you set the water level ( small - medium - large). The water level control is responsible to shut off the power to the fillvalve and direct that power to the timer so the washing machine can start up.The WLC has electrical contacts in it that sends power to the fill valve and whenthe WLC is satisfied the water level is correct the electrical contacts openpower to the fill valve and send the power to the timer and the washer starts.Picture of this here. How the water level control knows when it istime to shut the water off is, a air tight hose runs from the outer washer tank to the waterlevel control. As the water fills the outer tank air is pushed up the hose,depending on which setting you have made ( small- medium - large ) is takes acertain amount of this pressure to make the WLC cycle over and shut off the waterand send this power to the timer. If this hose develops a leak or a pin holethe washer can over fill as the WLC may not be able to shut the water off. Thewater level control can also break down and allow the washer to over fill aswell.
Testinga water level control or a fill valve can be done by using a Testing a water level control ora fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter.
You can get required parts from www.repairclinic.com
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Jan 16, 2010 | Zanussi FJS1225W Front Load Washer
Maytag washer - the water will not stop running
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to. the another possible fault can be ------------ The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Jul 13, 2009 | Maytag PAV2300 Top Load Washer
The washer filled up with water and just started to tick, didn't spin, didn't wash. What should I do.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
click the link
http://www.applianceaid.com/maytagwash.html
Nov 29, 2008 | Maytag PAV2300 Top Load Washer
Agitator wont spin
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Water level switch doesn't shut off the water
Washer Basics: Filling with water:
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
